-   -   I need a softer set-up ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/511398-i-need-softer-set-up.html)
flmont 11-16-2009 05:05 PM
I live in Tucson,az,...and the roads here are not good at all,..I now have adjustable Koni's on the front(soft setting) and it beats me up,..I dont flow over the roads I bounce over them and they are truely very rough how can I soften the ride.It feels like Iam going to snap something driving local roads ????? TIA Frank
Chuck Moreland 11-16-2009 05:10 PM
What are your suspension specs now?
Torsion bar size
Koni yellow or red
what are the rear shocks
ride height
tire size
flmont 11-16-2009 06:08 PM
I belive its stock,...I have a 77' Targa and I used red koni's,...FM
flmont 11-16-2009 06:11 PM
as for ride height its very low set at around 24" maybe 24.5 front and rear...I dont know what the bar size would be...15" tires aswell FM
sc_rufctr 11-16-2009 06:20 PM
There's not much you can do to soften it up without swapping out components.
I have a through body Weltmeister anti roll bar on the front. The ride on my car was very harsh when i bought it.
I moved the link arms further out on the adjustment arms and this had the effect of softening the suspension.
Also adjusted the rear - Weltmeister as well.
They were almost hard against the stops when I bought the car.
You car being stock would have the non adjustable bar that is installed lower down outside the body.
I'm not sure if this helps.
chocolatelab 11-16-2009 07:04 PM
maybe check the bushings
the ones on my 78 are beat, replacing them as we speak
also a return to a normal ride hieght may soften things up
cant wait to hear from the experts
thanks for the question
Chuck Moreland 11-16-2009 07:05 PM
A complete tire size is what I was looking for eg. 205/50 15.
But it looks like the problem is your car is too low. With stock tbars and that height, you are likely hitting the bump stops regularly. That makes for a very harsh ride.
Increase ride height or make suspension mods to allow you to safely run that low height.
flmont 11-16-2009 09:05 PM
Ok Chuck Thanks ,. but what type of mods could be done,I have little experience with P-Car suspension
flmont 11-16-2009 09:06 PM
Oh I will need to ck on the tire size,....Thanks Frank
flmont 11-20-2009 02:59 PM
man I measured my ride height (rear) 23" yes 23 " I sure thought it was set at 24" in 05' Bad shocks ???? FM
