engagement with concentrated Techron...
Just to pass on a story....
I added a 12 gallon treatment of Techron to the tank,..which had (~) 3 gallons in it (MAX)...I ran the dog out of it for about 15 minutes interstate level (yes, with the high levels of Techron) ....then pulled in for an additional 6 gallons of 93 octane (she sees this octane every day...). Proceeded to log another visceral 38 miles then she parks for the night...I know I'm still under the the treatment ratio.... The next A.M., we head off early, and not only 1/2 mile down the road, she bogs completely in 3rd gear,..liking only to attain idle,.........any request from the gas pedal was met with instantaneous bog down (throttle sags,..engine wants to die). I pull over,..look into the rear,..play with the throttle ass'y and eventually get an instantaneously response...head up the road,..about 1 1/2 miles, she does the same thing again.....I repeat my process,..now wandering if the Techron mixture "did something overnite",..and having withdrawals to get to a station to top this tank off.....I drive home....ponder the situation and decide to go for it,..hit the station,..topped her off.....and went for a 40 mile run...unninterrupted. As soon as I got home,..changed the fuel filer out,...took her out for another 50 miles of revving backroads....like a new frikin car (butt-seat-dyno). I believe my injectors are happier these days.. Point is,..make use of the "cleaners" on the fuel-side, no? Techron seems to work for me. Maybe some of you can share your expertise, experiences and treatment cycles. My best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I use SeaFoam in my fuel and have no problems whatsoever. I use it all of our vehicles.
Very strange result of a fuel additive. The only idea I have is that it freed up some junk which got into the injectors(some or all).
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
at least the filter is new?
She ran perfevtly tonight,..instant throttle....
muck-raker
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
actually, she ran "perfectly" (not perfevtly,...WTF?)
I know,..it make me wonder if it was the ratio that caused the "bug".....or,..is it that "coincidental" thing, having more to do with sensors, etc.? You gotta' love these mysteries........bug up a butt makes me nervous.....luckily, I was only a few miles from home. Time will tell,....... Best,
Anybody cut a fuel filter open lately? Best,
LOL........I do that all the time to provide a "snapshot" of whats in the tank and what kind of condition its in,....
![]() IMHO, its good practice providing one uses a proper filter cutter instead of a saw.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Alii&Maui
Sounds like the Techron is cleaning your system and the bogging is some bad stuff passing thru the system.
IMO |
Amen!!!!!!!!
You may have also picked up some garbage from the bottom of the fuel tank with less than 3 gallons left.
I think it's been posted before to not let our tanks run below 1/4 tank.
Checked out
given that the fuel pump pickup is in a fixed location in the tank, in a moving vehicle with a contantly sloshing gas tank, why does it matter how many gallons are in the tank, as far as "picking up garbage" from the bottom of the tank?
Second that--I've driven mine until the low fuel light came on (I didn't know it worked) with no harm done. David
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
Eh, that must be an old wive's tale. Carry on.
