-   -   O2 Sensor ? (http://forums.pelicanparts.com/porsche-911-technical-forum/512328-o2-sensor.html)
audiman08 11-21-2009 12:41 PM
O2 Sensor ?
This may be a dumb question, but I'm relatively new to 911s. I decided to remove my heat exchangers on my '75 911 S and replace them since they were rusting. I also pulled out the cat, and plan on replacing it with a cat bypass (since historic vehicles as exempt from emissions testing here). Anyway, I was looking for the O2 sensor and couldn't find it....anywhere. I am wondering if the previous owner unplugged it and adjusted the mixture to run lean. It doesn't seem I've been running very rich, but I'm a little concerned what this did to my engine. Where does the wiring run so I can put an O2 sensor in, and will I need to readjust the mix if he's tinkered with it? Thanks
kodioneill 11-21-2009 12:53 PM
1975 911's did not use an O2 sensor.
audiman08 11-21-2009 01:51 PM
Oh, well that makes it easy! Thanks :)
