1970 911E
Rear interior panels and retractors
I have a 1970 911 E that has had retracting seat belts added by bolting the retractors down to the rear floor. I'm redoing the interior and I'm wondering if I can mount the retractors under the side panels (as the later models did). If so will getting 72-73 rear side panels work to tidy everything up? I'm not familiar with how these were mounted and/or if there are different size retractors so any input or advise would be appreciated.
Thanks,
Alex
Old 11-22-2009, 04:06 PM
PCA7GGR's Avatar
Yes you can mount the retractors under the side panels. When I did this in my '70 tub, I found a tapped hole in the tub that I used for mounting the retractors. They landed up being a bit off center but it works well with the '72-'73 side panels that have the slot for the belts (make sure you also use the plastic inserts). I also bolted a newer style receiver between the seats using bolts and nylock nuts.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 11-22-2009, 04:19 PM
1970 911E
Retractors and side panels
Thanks so much for you detailed reply and photos. That was very helpful. I guess I just need to find the 72/73 side panels now.
Thanks again,
Best,
Alex
Old 11-22-2009, 09:26 PM
gulf908's Avatar
Alex,
The side panels shown above are for the '74 MY onwards.
They may work well as Sergio has described but the '73 MY and earlier are a bit smaller.
It depends on how correct you want these to be.
There was a thread on the Early S site about this very topic in the last week or two.
These are what you should be looking for -
Cheers,
Dennis.
The 914-6 from my 'Lotto'garage has finally arrived.
1971 911S 2.2.
1975 Carrera Targa (ROW) - missed.
One of us is fast becoming a valuable antique.
Old 11-22-2009, 10:43 PM
