autothority vs Steve Wong
After a few informative emails from Steve Wong I ordered a DME chip for my '88 Carrera. I opened the box today to install it and discovered an Autothority chip already in it. I called Autothority to find out what the specs on the chip are and got some guy who was, let's say, less than helpful. According to him all the Autothority chips for my '88 911 are the same (though mine says "version 2.5" on it) and all 911s use "premium" gas (specifically what octane? - no help with that question). Steve will make a chip for either 91 or 93 octane.
Anyway - aside from dealing with the company, any experience with the Autothority chip? Can I expect any improvement with the SW chip or should I send it back? |
The original Autothority that knew Porsches is long gone. Current owners seem to be more interested in Japanese cars.
Back in the day when Al Collins and Larry B were doing the chip work, they were THE experts. I had one of their chips in '84 in my old 944, then they used my previous '86 to run on their dyno to develop their MAF conversion kit. I still have a box full of their software, including one of those v2.5 chips. It worked pretty well though was known to run a bit richer than necessary to be on the safe side. Unless it says 91 octane, all the v2.5 were made for 93 octane. I'd be curious your back to back seat of the pants comparison between the two chips. I bet Steve W's software will offer better drivability and slightly better throttle response. He does more development these days than Autothority did back 20 years ago. |
Steve Wong is the only way to go
My '86 had an Autothority chip, a cat bypass pipe, and a single in, single out Monty sport muffler. It always ran rich and I had to put the stock cat back on because otherwise it would "backfire" when shifting from 1st to 2nd at high RPM. Autothority blamed the "backfire" on the exhaust and was no help after the sale.
Years later after reading all the great reviews on Steve Wong's chips, I installed one along with a Fabspeed premuffler to replace the stock cat. Steve's chip made the throttle more responsive throughout the entire rpm range. Steve's chip also seems more sensitive to input from sensors. I had to replace an old O2 sensor and the head temperture sensor to get the mixture to adjust correctly. Steve was very patient, replied quickly to all my emails, and helped me make all the adjustments to get my car car running better than it ever has. I also had a unique problem with the idle control switch switching on at the wrong time. This one took a while to figure out and at one point I put the Autothority chip back in to compare. With the Autothority chip back in the throttle response felt numb. The Autothority chip also ran too rich, start up was rougher, and the high RPM "backfire" was back. Because I was busy with work and other projects, it took me a long time to sort though the adjustments needed to get my car running just right. (my fault, not Steve's) At one point I even had to store the car for the winter, and work on the idle control switch problem in the spring. Steve continued to help me sort though the issues of a 20 year old car until his product was working the way he designed it to work. The car is much more fun to drive now and it even gets better gas mileage. The time spent sorting things out and getting it all right was well worth it. I can't remember ever having such good customer service during and after the sale on any product. |
Sell the Autothority chip to help fund the SW chip.
-Andy |
I too bought the SW chip especially for my '86 Carrera (with headers and M&K 2in/2out) only to find it had already had been chipped with the Autothority at some point in history. Back to back runs on a local dynojet documented in my case the Autothority chip was up ~5 hp (229 at the wheels) and the air fuel ratios were also better especially above 5500rpm. The SW chip also caused my car to stall when the clutch was pushed in and the rpm's dropped fast. The idle was correct, but it would fall straight through idle rpm to zero unless it was blipped. Steve offered to adjust the air/fuel, but I eventually just sold it for a small loss and re-installed the Autothority chip and never looked back..... your results may vary!
Steve Wong ship 100x better than Autothority.
I switched over, and saw incredible change for the better. Like other's have said.... Do a search and you will see why Steve Wong chip is so good. |
Wong is the man!
Great guy, great chip! I am a happy customer! |
Not only is a Steve Wong chip a great upgrade for any Porsche but you also get first class tech support and communication from Steve.
When someone can spend over 20 minutes on the phone explaining his product to a total stranger,it says a lot about the person and his dedication to his product !!! Phil |
There is simply NO question here. Steve is the man.
http://forums.pelicanparts.com/uploa...1259266916.jpg |
As my car can't be chipped, I have no FHE with either product. But one thing that would go into my purchase thought process is the fact that Steve is a fellow Pelican who's only an email or phone call away. In these types of custom applications (where your mods will be different than the next guy's), I think it's important to have that type of individualized customer service so readily available.
I'll raise my hand on this one. Opened the DME and found an Authority chip, installed the SW chip and it was like night and day. A year later I installed a cat bypass, deleted the 02 and Steve remapped the chip (reasonable incremental $$). More power, better midrange, lots more smiles.
High fives for Steve's work. |
OK, I really have to chime in and say......wait, it's all been said. ;)
Autothority chip discovered.
I found the following comment on an old post;
Looks ancient to me. Aha, looks like the explanation to the poor mileage (~17) after hjaving read posts about the typical richness of their chip, but here is the question. I can compensate for some richness by turning the DME adjuster pot to position #7 ( IIRC) It is set to 0 now and position 7 moves the fuel map to lean ~4% leaving the timing map stock. Without a wide band air/fuel ratio meter at my disposal has anyone done this to compensate for the Autothority mixture map. I would not like to spring for a SW chip now and I must say Autothority claims an 18 hp increase for the stock 3.2 plus I have Bursch 1 5/8" headers with an M&K 2/1 muffler that must be good for ~15hp on top. No wonder it revs like it does, but I don't track/race so I would like a bit better milage. BTW its a 28 pin chip. Thanks , George in Miami http://forums.pelicanparts.com/uploa...1386559211.jpg |
Sounds like Wong will make it right...
Let me simplify the question.
Has anyone corrected the rich AA condition by simply turning the setting on the DME to a different number? |
17MPG (highway? you don't say) is horrible, sounds like something more than just the chip running a little rich.
You could try the switch, but from my notes position 7 (or 8, depending on where you start counting) also pulls out ignition advance. I've always held the DME FQS (Fuel Quality Switch) settings for our 911's are as follows: Switch Fuel Ignition 1 0 0 stock setting 2 +3% 0 3 +6% 0 4 -3% 0 5 0 -3deg 6 +3% -3deg 7 +6% -3deg 8 -3% -3deg If I wasn't programming my own chips I'd spend for a custom chip - From what I've heard about Steve, you can tell him your header/muffler combo and he can come pretty close with the fuel/ignition settings without any dyno runs. Chuck.H '89 TurboLookTarga, 369k miles |
I found a Autothority chip installed in my 85 3.2 as well. My car runs great and got 24 mpg on a long road trip. It has also passed it's last 7 Southern Cal smog checks. I remember the Autothority chip was all the rage for Porsche cars 25-30 years ago. They were in all the mags like Road&Track and everyone installed one in their 944. I'll just let it stay.
Same thing happened to me, as to "discovery.
I (ultimately, in to ownership) made discovery of an Autothority chip resting within my DME. I installed a Wong chip (customized, as Steve will certainly do JUST THAT for you), removing the previous chip. The AU chip had been in for a couple or so years and the Wong install made dramatic differences. No chances to quanity on a dino, but it was there, no doubt. I've wanted to get with a friend to read out this AU chip to see what they were doing vs. Steve's setup. Later, I found a few threads on it. What's so (NOT) funny is that I made the discover while gassing up the girl one night. I happened to look down at the inside of the gas lid and noticed the stiker (93 octane minimum,...and why). The very next morning, I had Steve's chip on it's way. Couldn't believe it. BEST! Doyle |
Heck, in a few years the Wong will be gone because it will not be cool anymore. We will be buying a new super chip from Samsung that is voice activated. ( S Voice?). You will hit some crazy mountain roads and command..... "Activate mountain road program".
Yeah, setting #4 is the one I was asking about if anyone has used to compensate for the Autothority rich running issue. Also the 17 mpg is mix if mostly city/suburban and some hiway. I suspect the person getting 24 hiway with the Autothority chip has the setting 4 on the ECU. I am tempted to try setting 4 for a 1/4 tank of light hiway cruising, if it goes to 24-25 its prob ok, any more mpg than that and its prob too lean. OR the old fashion way.....a quick short blast at hi speed and read a couple of sparkplugs. |
Steve just made some improvements to his 911 chip and some users are reporting markedly increased fuel economy.
Chipping a 911 really is not like it used to be when it was one of the fastest cars in town. Now there are so many regular cars that are so much faster really why bother? An 84-89 911 is much fun to drive anyway just the way it is. Have you never had a Subaru WRX or 400H.P+ Mustang or Dodge Charger or Challenger pass you like you were standing still? Dang, they are fast!
Couldn't say it any better.. SW is very helpful and I too am a very satisfied customer!! |
| All times are GMT -8. The time now is 07:42 PM. |
