Headlight Washer Switch
Can anyone tell me if the dash switch for the headlight washer system is spring loaded meaning it returns to the off position after releasing it or is it only on and or off depending on the position. 1980SC model.
thanks for any and all help. |
'82 SC TL
It should spring back to original position - press once (while lights are on) & let go
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Just to add, I need to hold mine down until it's provided the amount of headlight washing wanted -- once I let it go, it springs back to off. Also, my headlight washer circuit only works if my headlights are on
