Help 968
gents
i may be selling the 84 carerra and buying a 968........need room for 2 sets of golf clubs the 968 forum doesn't seem to be as active or critically tuned as you guys... so: any thoughts on the things that go wrong w/968? i've checked everywhere on the web before bothering you real porshcephiles, but no luck and, if i need a PPI near hermosa beach; any suggestions. tx
ed ed's flyfishing outfit bozeman, mt '92 964 C4 chevy p/u |
timing belt ballance belt water pump service. also twin cam connecting chain failure
tx
be sure and check the rennlist forum
i'll do it
Hello. I actually looked at a few 968's before I bought my 911. They're very nice cars just no what I was looking for. The water pump/ timing chains need to addressed. There is one other issue that escapes me at the moment. I believe it has something to do with the pinion gear? in the transmission. As suggested definitely check out Rennlist for additional info. The 968 is a fun car to drive, very well balanced and quite a bit of torque. Also a very handsome car IMO. Good luck with everything.
Chris
Chris 95 993 C2 ![]() 84 911 gone to to a new home |
it's painful thinking of going from a hot rod to a sedan
I am sure the 968 is a fairly underrated car. I looked at one before I bought my 911. Call me shallow, but the minute the salesman called it a hairdresser's Porsche, I was done.
For it's day, it had the most powerful four cylinder engine on the road by a good margin and good weight balance. I would take one over a 944 or an automatic 928. They are pretty unique as well. You just have to be confident in your masculinity.
_______________________ Unless you change your course, you are likely to end up where you are headed. '87 Carrera, Black on Black |
Owner, Callas Rennsport
Ed, I am willing to offer 968 advice but would like detailed information on this car.
Year Mileage Service history Transmission type Cabriolet or coupe What has been replaced recently
Owner, Callas Rennsport Phone: 310-370-7038 Located in the Greater Los Angeles Area http://www.callasrennsport.com |
Platinum Member
Have you thought about a boxster?
I had a 968 for 4 years. It was a great car. The 968's were the only front engine 4's that were totally built in Stuggart and have something like 86% different parts than a 944. It was fast, handled exceptionally well and was real comfortable. I can't say anything bad about them. Problems - #1 Pinion gear, #2 Camshafts. Why did I sell it? I like vintage Porsches like my 356B and my 67 911's, and didn't have the space and resources to have more than 3 at a time.
Bill B. 63 Little B Coupe 67 SWB 3.63 Hotrod 08 Cayenne S 65 F100 |
I looked at 968's as well and was real close to buying one but never pulled the trigger. This site was real active at the time but I think the person who maintaned it sold his car and bailed on it:
968.net Check out REnnlist and I think there is an active UK site that has good info.
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
Mike Holbrook
I like the 968 Coupe. Don't care for the rag top too much. I had a 944S with the 16valve engine. Very smooth and fast, very well balanced and comfortable. Most of the problems associated with the 944S were fixed in the 968 as I understand. Hard to believe the 944/968's came from the same lineage as the 911.
Now that I own a 911, I don't think I could ever go back to a water cooled Porsche. I prefer the SC and Carerra. I guess if you "have" to carry two sets of golf clubs......couldn't you do OK with just a 5 wood, a couple wedges and a putter.
Mike Holbrook Meridian, ID 1979 911SC Targa |
Do what I did, kept the 911 and bought an AMG, Kevin
Virginia Rocks!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
wow i had a 944 for 2 years way more modern air heat daily driver then my 911. I think the hairdresser statement is a little much dont you think. Kevin
Go directly to your nearest independant air/oil cooled Porsche repair facility and have your attitude adjusted. Dump a Carrera for golf clubs? Something must have gone awry.
just an option but take out the passenger seat and you will have plenty of room for your clubs , if your need two sets because your golfing with them either make them sit in the back or drive themselves ...
