Mystery engine
Here's an odd one. '70 coupe in for an o'haul. No numbers in the usual places, but after cleaning found them at the flywheel end. 901/38 type, 6404726 serial. Nothing close in the spec books. Expected a 2.2, was a 2.0. Heads dated 11/69, way out of the 2.0 range. Guessing it was a factory replacement engine, or maybe a 914/6.
Got 2.2 P&Cs and found a set of 9/69 2.2 heads in my stash, so it will become a proper 2.2, but what the hell? Thoughts?
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 06-11-2021 at 11:02 AM.. Reason: corrected serial # |
thing are a little strange ..as we have spoken ..the engine i`m just about to finish is 1970 911S 2,2 but had the rods from 2,4.....drove me nuts to get the correct parts;-)..
Ivan i guess the masters who knew these tricks are no longer among us to shed the light on these things...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
gearhead
Isn’t that a 914/6 engine?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
That’s a 914/6, basically a 69T engine continued on till the end of the 914 program
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 06-10-2021 at 04:31 PM.. |
Kinda thought it was after seeing the numbers at the flywheel end. Wasn't expecting it, as I bought 2.2 P&Cs for it, so luckily I had some 2.2 heads.
Keep those 69 heads. It’s got a nice valve size for a 2.0 liter build. Just need to port the intakes.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
The 69T and 914/6 heads have the same valve size as a 67S. It’s a economical way to start a 2 liter performance build.
Got a '68L bottom end that I could use them on. The pistons have a nice high rounded dome too.
gearhead
Maybe the pistons were already upgraded? What cams were in there?
Stamped 03 on the ends, so stock T.
