Pls help identify this clutch, change it or keep it?
Hello,
The car is a '72 with original 2.4L MFI and 915 transmission. I pulled the engine to replace the oil seal behind the flywheel. I was surprised to find this clutch. I haven't seen one like it before and couldn't find it in the parts section. It is not marked "Sachs". The thickness is 76mm. Should I keep it or replace it, while i'm in there? http://forums.pelicanparts.com/uploa...1259444101.jpg http://forums.pelicanparts.com/uploa...1259444474.jpg Thanks, Adam |
Strange. I don't see anything like it in the Pelican catalog to compare.
I would swap it for a new one, though given that it is the original. |
Thats the rubber hub clutch of years gone by. Feared by some and tossed by many..
Bruce |
Yep , Borg-Warner made these among others I imagine.
The rubber center had a tendancy to disintegrate. |
Thanks guys.
Time for a new disk! |
You ARE going to purchase a complete kit, right?
That flywheel looks pretty beat up to me. The SACHS sport kit is a great setup for a street 911. |
| All times are GMT -8. The time now is 07:33 PM. |
