-   -   A/C bracket ? (http://forums.pelicanparts.com/porsche-911-technical-forum/513950-c-bracket.html)
my1st911 11-30-2009 05:47 PM
A/C bracket ?
I'm finishing up on my 2.7 rebuild and casesaver install. My car cam with A/C that was installed at the port, but the compressor and bracket was missing from my engine. Can someone please post a pic of how and where it attaches. I realize its on the passenger side, but I havent found the correct mounting location. Thanks
Jim Sims 11-30-2009 08:40 PM
http://forums.pelicanparts.com/uploa...1259642220.jpg
Plus see the below thread which shows two of three mounts but not the short bar strut (item 8) attached with a special nut (item 10) to one of the passenger side chain case to engine case mounting studs.
http://forums.pelicanparts.com/porsche-911-technical-forum/344432-air-conditioning-re-visited.html
my1st911 11-30-2009 09:15 PM
Thanks Jim, I searched for a/c bracket, and couldnt find anything. Your pic is great. I thought the bracket mounted to the case itself. Since the motor mount bracket is at work, I didnt realize that it bolted to that instead. Thanks again. Here is a pic toohttp://forums.pelicanparts.com/uploa...1259644508.jpg
