Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Replacing plastic fuel lines
My car still has the original black plastic fuel lines going from to the fuel distributor to the injectors and WUR.
I would like to replace the line going to the WUR as it is somewhat tight / short. Also replacing 36 yrs old high pressure fuel lines seems good practice too...
The question is, can I replace them with something else ? those hard plastic lines are a PITA to fit. Is there an alternative that fits my fuel distributor and the WUR (it's one of the early ones with barbed lines coming of it) ?
Old 12-01-2009, 08:06 AM
HarryD's Avatar
You may be able to use the later hard lines for the fuel distributor to injector lines. I am not sure of that if there is a hard line for the WUR. For that one, you can get some gfasoline compatible Nylon 6 line from McMaster Carr (McMaster-Carr).
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-01-2009, 01:09 PM
