Wickd89's Avatar
Dash heater vent diverter not working??
I need some help. I have heat coming to the front when I pull the heater levers but 90% of the heat is coming out of the side vents that are located on the dash of my '89 cab....
I change the controls to defrost (windshield) and that works.
I change the controls to footwells, and thant does not work.
Help. What to do?
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 10-18-2009, 12:37 PM
Cattler's Avatar
Porsche Crest
I have the opposite--nearly all of my heat goes to the windshield and very little to the side vents. I've been able to slightly improve the situation by checking out the cable connections on the fresh air system in the front boot. I lubed and manipulated the levers--that worked some. I intend to disassemble and reassemble sometime later this fall.
Anyone done this?
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 10-18-2009, 12:50 PM
Wickd89's Avatar
I did this as well and will try again. is this a manual connection or does the dash lever work a servo??
Old 10-18-2009, 01:41 PM
The levers on the dash are connected to valves on distribution boxes in the trunk, via cables that resemble bicycle brake cables. If you have somone operate the levers while you observe the resulting action in the trunk, you can figure out what needs to be fixed.
JR
Old 10-18-2009, 02:24 PM
Wickd89's Avatar
I just did the "two man" check of the cables. Everything is working. I will test drive it and see. Could be that the actual flap is stuck. If so, were are the Flaps located in? I assume just inside where the wire is connected in the ducts in the trunk...
Old 10-18-2009, 03:11 PM
Cattler's Avatar
That's right--they're simple flappers without servos. The dash levers pull on the cable, the cable pulls the levers in the boot, those levers manipulate the valves. Its all mechanical, no special electrical components.
Old 10-18-2009, 04:51 PM
OldTee's Avatar
So like where is a good description of this silly system. One with diagrams, where stuff is located. The PORSCHE workshop manuals are useless, or at least the volumes I have (Vol III thru Vol VI).
How about a hint where to find the information.
Old Tee
all 911s sold
Old 12-03-2009, 09:19 AM
There's a ton of info on this forum, if you can find it with a search. I know I have posted about in in many threads. Most of what I know I learned by woring on it. Once you have a few parts in your hands, it's easy to figure it out.
What, exactly, do you have questions about?
JR
Old 12-03-2009, 09:28 AM
aj88cab's Avatar
Before you start pulling apart the flapper control boxes in the trunk, remove the footwell side panels and make sure all the hoses are connected and not cracked, then check the ones in the trunk too. If the hoses are good its a good bet the problem is at the cables at the flapper control boxes in the trunk as other's have mentioned. The cables are attached with spring clips that could slip or there was work done on them and they were not adjusted properly when reinstalled. The ends of the cables have screw clamps that could have slipped also. The Bentley manual has good pictures and a description describing the adjustment proceedure.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 12-03-2009, 11:35 AM
If the diverters are not property diverting air, then there are two thinks to check. First off one of the air hoses from the fresh air plenum and check the rubber on the diverter flappers. If rotted, take the fresh air blower housing off the plenum and take apart then make replacement rubber seals for the flappers using 1/16 " sheet rubber found in plumbing supply, works great, takes time to remove and install.
Old 12-03-2009, 08:25 PM
Wickd89's Avatar
Thanks everyone, I plan on going in this weekend and checking it out...
Old 12-03-2009, 09:53 PM
chocolatelab's Avatar
its not that bad to take apart the cables and flapper boxes for a cleaning and lube. Take a bunch of digital pics because putting it back together can get a bit goofy.
Carefull with the little clips. You need needle nose pliers to take them off but wear safety glasses because they will fly.
My controls werent working because the cable housings had kinks. I used bike cable housing as a replacement. you still need to save the original inner wires. treat them with care.
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 12-03-2009, 11:21 PM
Spiderman
Jesse16's Avatar
And another comment about "before your pull too much stuff apart". Remove 2 screws that hold on the the floor vent covers, take a look and make sure the PO didn't cover over the vents to eliminate floor heat as my PO did. They all lived in Florida/Georgia and I have no idea why. When I removed a bunch of duct tape and plastic bag material, I now have plenty of heat to the floor where it belongs.
Old 12-04-2009, 05:54 AM
