GaryR's Avatar
Send a message via ICQ to GaryR
Timing curve for 3.2SS
10.5:1, SC crank, 98mm Max Moritz cyl set, S cams, 46 mm Webers with 38mm ports, Electromotive crankfire. I need a base (400-1000 RPM) advance setting, then what it should be by 3000 RPM, then max advance up to 8000 RPM. The difference between 3000 and 8000 can be more advance or less advance by 10 degrees either way.
Gary R.
Old 12-03-2009, 02:27 PM
