SC Ray
81 SC Ray's Avatar
Best penetrating oil??
From the weekend warrior garage,
I have to change out a broken heater valve (you know, two of em - left and right) - the bolts are really rusted and I am afraid to break a stud. What is the best penetrating oil - I have never tried to loosen anything so rusted. Fortunately, this is the only rust on the car.
Thanks for the help.
Ray
Old 11-24-2009, 02:22 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
PB Blaster for me, but others feel free to chime in.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 11-24-2009, 02:23 PM
Senior Member
Superman's Avatar
Maltby's. Can be hard to find, but diesel parts stores usually have it.
Mocha 1978 911SC. "Coco"
Old 11-24-2009, 02:24 PM
pete3799's Avatar
PB blaster, but you will still have to heat the nuts to get them off.
Don't even try them without heat.
Pete
79 911SC RoW
Old 11-24-2009, 02:29 PM
ATF with varsol in it should work fine. Or ATF and diesel fuel. Or ATF, diesel and brake fluid. Mix up what you got on hand.
The heat is more important than the oil.
Old 11-24-2009, 02:36 PM
Green Skull 006
Jim Garfield's Avatar
This was recently posted by Curt Egerer on the S site:
"From a friend:
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating Oil Type ..... Average Load to Free
None ....................................... 516 pounds
WD-40 ..................................... 238 pounds
PB Blaster ................................ 214 pounds
Liquid Wrench ........................... 127 pounds
Kano Kroil ................................ 106 pounds
ATF-Acetone mix..........................53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "LiquidWrench" is about as good as "Kroil" for about 20% of the price."
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 11-24-2009, 02:40 PM
MBAtarga's Avatar
I've also had recommended to me a 50/50 mix of acetone and ATF. I haven't had the opportunity to mix some up and try it out though.
Edit: Jim posted the above as I was typing my response. Scientific evidence that ATF-Acetone works.
Mark
'83 SC Targa - since 5/5/2001
Old 11-24-2009, 02:41 PM
walt's Avatar
I have used Kroil for years as do many of the local machine shops - works great. I would like to try the 50/50 mix next but will need to exercise caution around painted finishes.
Walt
Walt
82SC 3.0
81SC 3.6
Old 11-24-2009, 02:54 PM
Awhile ago when I stopped in Portland to visit Steve Weiner, he gave me as a parting gift a new can of Zep Super Penetrant. So unless it was something he was desperate to get rid of, I take that as a knowledgeable recommendation.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
IROC's Avatar
Walt
+1. I had a can of Sili-Kroil that was the best stuff I've ever seen.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-24-2009, 03:04 PM
3.4 Bigger is better
88-diamondblue's Avatar
+1 on the Kroil. I have used other but none have worked as well
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 11-24-2009, 03:28 PM
AutoBahned
RWebb's Avatar
PB Blaster works well but stinks - I like Kroil.
Loctite now makes a Freeze-Off product which I plan to try next time I need it.
Wurth makes a product too.
The comparison above is hard to interpret as no sample sizes or even test methods are given.
I would never use acetone in a garage. It is toxic and dangerous (ignition hazard).
THe most important factors in any penetrating oil (WD-40 is not a penetrating oil) are time and tapping the joint - so ap it hundreds of times over a week or two after spraying.
Old 11-24-2009, 03:38 PM
winter
Winter's Avatar
If you use Liquid Wrench, let 'er soak. And then hit it again with the LW and let 'er soak, and again. . .
This has worked very well for me, and I'm talking doing the process over a couple of days. And Liquid Wrench is easy to find, relatively cheap.
The suggestions from others here sound good. I've heard good things about Kroil, but haven't run out of LW yet. When I do, I'll try that.
Tom '75 targa
Old 11-24-2009, 03:45 PM
Frosty the A.I.
Wintermute's Avatar
Wintergreen Oil. Seriously.
Wear gloves.
Old 11-24-2009, 03:58 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Aero-Kroil, really works!
Gary R.
Old 11-24-2009, 04:11 PM
And note how cheap it is to make. Spray lube is way overpriced.
Old 11-24-2009, 04:30 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Mouse milk is the one to beat...
Welcome to Mousemilk
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 11-24-2009, 04:40 PM
sudo apt-get purge 930
equality72521's Avatar
One more for Kroil. i bought a whole case of it.
--clutch-monkey
Old 11-24-2009, 04:50 PM
SC Ray
81 SC Ray's Avatar
OK - you guys rock - thanks, but, I want to expand my question. I have always done my own work on my cars, but, my cars have never been 28 years old before. So, I have never had to use penetrating oil - from your responses, I am gleaning that I am to:
1. Apply it many times over as long a period as I can.
2. Tap the bolt - the nut - both??
3. How do I "let it soak" when it is a bolt/nut assembly that is perpendicular to the earth on a vertical piece of metal.
NOTE - Thanks for the scientific evidence. I will be going to Autozone and mixing up a batch of acetone and ATF - I will be careful with it (damaging paint - death - all bad).
Thanks.
Ray
Old 11-24-2009, 04:59 PM
dshepp806's Avatar
Kroil....
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
