9146FAN's Avatar
Flywheel Bolt Torque Spec?
Can someone tell me the torque spec. for the flywheel bolts on a 2.7-S crank with a new 215mm 911 flywheel?
Yes, I have new bolts.
Thanks in advance.
Old 12-03-2009, 08:45 PM
I believe if memory serves me 104 flbs
regards
Old 12-04-2009, 07:19 AM
Somatic Negative Optimist
Gunter's Avatar
What size are the bolts?
Wayne's Engine Rebuild Book should have it in the back under "Torque Specs".
If they're M12 x 1.5 mm, 110 ft-lbs. Notes: Make sure flywheel washer is in place and use red Loctite 271.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-04-2009, 09:57 AM
9146FAN's Avatar
Thank you again gentlemen.
Old 12-04-2009, 08:07 PM
