Oil Pressure Sensor 3.2
Gents, how easy (or hard) is it to replace this unit?
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
Apologies. Should be oil pressure SENDING UNIY
Pretty quick and easy. It's just to the right of the fan. Unscrew the old one and screw in the new one. Shouldn't take more than a few minutes.
Sent from my SM-S931U using Tapatalk
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Here's an excellent procedure for changing out the oil pressure sending unit.
https://forums.pelicanparts.com/porsche-911-technical-forum/502982-another-oil-pressure-sender-replacement-thread-pics.html The low oil pressure switch for the idiot light is in the triangle of death on the back side of the engine. Different sensors.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
Very difficult to remove the sensor from the mounting block in the car. Far simpler to remove the mounting block with sensor still in the block. Then on the bench swap the old sensor out of the block.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
well..if you have the a/c it is kinda pita...after if you have the correct tools it could be an easy job but..look at this disaster Some idiot broke the case....
the best to go about it on 3,2 is this tool .If it does not budge remove the a/c bracket -for that you have to remove the muffler.as said above remove the complete block. As you can see not that easy..here is what somebody did and after they put J.B weld on it...told the client -sorry and here is the tool to loose the oil sending unit from the block.. BTW what is wrong with yours-you did not say? ![]() ![]()
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 05-14-2025 at 12:31 PM.. |
I'm not sure i understand why it's difficult to remove the sender from the block? Sent from my SM-S931U using Tapatalk
They likely broke the case because they did not remove the block with the sensor
I always remove the block then replace the sensor on the bench. That job in those pictures is a disaster! Sometimes it takes a lot of force to get the sensor out of the block, but getting the block out with sensor is much easier and requires little force.
Since i am talking about screw ups , have you ever seen this kind of repair on cylinder heads.Shaved and replaced with a metal spacer?that is another engine i am working on ![]() ![]()
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
A steel fastener in an aluminum thread will result in galvanic corrosion if you don't use something (like assembly lube, grease or oil) to prevent it. With the result that applying too much force to the sender while mounted on the car directs too much force via the hollow through bolt (that holds the block to the case), in a direction that the case material around the hollow oil gallery wasn't designed or intended to withstand. So the crow's foot approach, while it has worked for some, if not used cautiously can also lead to this scenario: ![]() From Broke of piece of metal, how to fix?
'77 S with '78 930 power and a few other things. |
I did mine a few months ago (86 Carrera with A/C) and it was a pain. took over 4 hours of tedious repetitive wrenching to get it free, and then a few more to get it to thread. I verified with close up pics that the copper washer was making good contact. for anyone without the A/C bracket, it's an easy job for sure. with the bracket, good luck. grab a few beers and let the cursing rip.
![]() ![]() ![]() ![]() ![]() ![]() and of course, with no A/C bracket its easy....
1986 Porsche 911 Carrera 3.2 |
stupid stupid question - how does that connector come off? Tried turning it, squeezing it, pulling it.
I really don’t want to break it. |
resurrecting this thread. After futsing around with the push on connector, I was on my way to my shop when holy crap, the gauge is working as it should. 1.5 bar at idle just north of 4 bar at 3krpm. Does a bit of bouncing as well. My expert says it is the wire connector. Early models had a treaded rod and nut to secure the connection.
So does anyone have a method to tighten the connector within the plastic housing? Was thinking if I could find a thin piece of copper I could wrap that around the terminal to try to tighten things up. Any suggestions are welcome And if anyone needs a 3.2 oil pressure sending unit I have one for sale.
PCA Member since 1988
Squeeze the terminal with a pair of pliers, slightly.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Still here
Now that I figured out my issue is connection between gauge and unit, what makes a “bouncy” needle? Just continued bad connection or the gauge?
Usually it is the sensor that is worn. Mine does a bit of bouncing too, essentially at idle, when engine is warm and oil pressure is around 1 bar. The sensor is a variable resistor, a sort of pot. Pot cursor must be wearing the part of the resistance where it spends most of its time. Hence a bad contact.
The gauge is an analog voltmeter, and they seldom fail this way. If needle bounces it only reflects the erratic signal it gets from the sensor.
Gilles RoW 88 Carrera coupé |
Thank you. Would a bit of dialectic grease help the contacts or is that inappropriate for this application?
