FinallyGotOne's Avatar
Question Whoa! what the heck is this?? Oil Leak
I have been thinking I NEED TO REPAIR MY OIL COOLER AGAIN But I have been driving the 911 sc anyways. It's holding oil OK>
Heres the thing I parked it and then after a couple days noticed QUITE a big amouint of oil right behind my driver side Rear tire.!!
What is in that area that would dump a good amount of oil??
Old 12-07-2009, 03:21 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Valve cover, cam cover, external cam oiler lines.
Gary R.
Old 12-07-2009, 03:23 PM
kodioneill's Avatar
upper valve cover. rocker arm shaft.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-07-2009, 05:14 PM
Lower rocker arm shaft and parked the oil level rises to that level.
Bruce
Old 12-07-2009, 05:32 PM
oil return tube seal?
206 637 4071
Old 12-07-2009, 05:52 PM
Diss Member
Quicksilver's Avatar
What oil related items are behind the right rear tire? Most everything...
The oil tank. Oil cooling lines. Oil return hose. Oil filter. Oil level gauge. Drain plug. Etc...
You need to completely clean everything so you can see clearly where it is coming from. It could even be coming from on top of the engine.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-07-2009, 06:21 PM
GaryR's Avatar
I like oil return tubes..
Gary R.
Old 12-07-2009, 06:23 PM
Danimal16's Avatar
I just had the same problem. It was the oil return line. It was finger tight. Had to remove the heat exchanger. However the entire repair took about an hour.
Dan
Old 12-08-2009, 04:41 AM
Heres a picture and a bit more explanation:
It's been sitting now about a week. the oil goes under the car. The only place where there is no oil is behind the passenger tire and about a foot to the left. Other than that it's like a big ole rectangle of oil spill!
I have the 74 OME Headers on by the way. If it ever warms up here in Colorado I'll get under there and try to see if the oil return line is loosened. Can that actually rattle itself loose??
Old 12-08-2009, 09:03 AM
safe's Avatar
That's an oil leak !
Magnus
Old 12-08-2009, 09:17 AM
that's typical of an oil return tube leak, after sitting a week. look at both ends of all the tubes with an inspection mirror and a flashlight. leakers have obvious oil collecting at the bottom of the o-ring area. and if you can turn the tube easily with your fingers, it's a leaker.
206 637 4071
Old 12-08-2009, 10:41 AM
Elombard's Avatar
Dude you are on the wrong side of the car :-)
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-08-2009, 01:19 PM
