want to dampen your p-car?
secondskin audio has b-stock sale going on for damplifier pro. $115 for 36 sqft.
http://www.secondskinaudio.com/viewproduct.php?id_product=356
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Damp.
You would not wat to make your P Car wet. (: Sorry, just a pet peeve.
JOHN 79 EURO SC "24 Years Later - The Dream Came True" |
uhhh ok.
I'll bite. What does this do ?
Its a silver foil noise insulation. You've seen the posts of guys that strip the seats and carpet and cover everything with silver foil, including the door panels. It does work.
I wish I had the ambition to tackle a job like this. The 911 is a noisy car, not very refined at all, my 911 is a raw 30 year old sports car with crank up windows, no tilt wheel, no cruise control, no compass or cup holders, no ECU or engine management system. Noise just goes with all the things that it is... agree? Last edited by white99c2; 12-11-2009 at 02:46 AM.. |
it's actually a foil backed vibration damper. it is not a sound insulator but rather stops metal panels from vibrating which greatly reduces noise. if you want an insulator (to actually block road noise) you need a closed cell foam of some sorts. this stuff is the first step/layer in making any car more quiet.
this link will tell you more about the product and has a little video as well. Damplifier Pro - Acoustic Vibration Dampening Mat
AutoBahned
dampening materials work by reducing the amplitude and lowering the resonant frequency of the vibrating panel
and, even a passing truck can cause a panel to vibrate the panel is like the drum head & the dampener is like the wads of chewing gum that some kid sticks on the drum head -- try it on the garage band next door |
AutoBahned
also...
I hear that you only need to do the center 1/4 of a panel to "work" |
i have heard that too, but the materials used to back that statement up were actually much thicker tiles. the foil is thicker on the tiles and i think the butyl is as well but i may be wrong.
AutoBahned
take a look here - I don't see any ASTM test methods used, but...
Sound Deadener Showdown - Your Source for Sound Deadening Products and Information |
i have never used any of don's products but they have gotten lots of good reviews. he was one of the first to make the thicker tiles and use the 25% idea as well. in years gone by he tested and reported on all sorts of products but took down that info once he started producing his own line.
