-   -   Oxygen sensor connection in engine bay (http://forums.pelicanparts.com/porsche-911-technical-forum/515954-oxygen-sensor-connection-engine-bay.html)
mschwien 12-11-2009 12:01 PM
I'm attempting to re-install an oxygen sensor on my 83SC (exploring some idle issues one thing at a time). The car has B&B headers installed by the PO and they do have the O2 bung - I'm looking for pics or a description of where the electrical connection is within the engine bay and I do have the female connector off of the sensor.
Thanks!
Mike
don gilbert 12-12-2009 05:13 AM
mike, the original conn. is on the left side of the engine compartment mounted on a bracket next to the cdi box, If its still there, as most have been broken off. If it is broken, You can just cut off the damaged connector, strip back the shielding and recon. using a butt connector. DO not solder, as the solder can act as a resistor on the milli voltage traveling the wire to the ecm.
mschwien 12-12-2009 06:17 AM
Thanks Don,
I also saw a picture of what the male connector looks like over in the classified section - with your comments I should be all set to go.
Mike
