-   -   Input shaft seal replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/516003-input-shaft-seal-replacement.html)
my1st911 12-11-2009 03:31 PM
1976 915 trans. I think its a mag trans, but reguardless, I got the two screws out, but can barely get the piece out. Any ideas would be greatly appreciated. Im trying to get it all back in tomorrow, and this is the only thing holding me back
1990C4S 12-11-2009 03:40 PM
I think I gave up with the 'pick' idea and drove a sheet metal screw into the seal, then pulled the screw with vice-grips.
my1st911 12-11-2009 03:44 PM
Even worse. I took the 2 screws out of the houseing that needs to be removed and cant get that to move at all. I can get it to spin left and right, but not wiggle out. Its thin and im sure brittle. I dont want to break an ear off. If you need photo, since I do not know what the piece is called, i can take oneSmileWavy
Flat6pac 12-11-2009 05:10 PM
The manual shows it beiing removed by slide hammer hooking into the 2 holes in the guide tube. I believe the seal sits in the guide tube, not installed in the case. I m on memory for that statement.
Bruce
my1st911 12-11-2009 05:11 PM
I got it. tapping it back and forth, and a pry bar pushed it enough to get a flat blade screw driver in between the trans and the housing to pop it out
my1st911 12-11-2009 05:53 PM
Bruce
I believe you are right Bruce. I didn't bring a slide hammer because I didnt think i needed it. A slide hammer would have made the job easier, but I got the housing out. The seal is in the housing, but I didn't realize that it had a round o ringg. I'll have to hit the auto parts store in the am for an o ring. Thanks for your help
