-   -   Bosch 3.0 curve chart (http://forums.pelicanparts.com/porsche-911-technical-forum/516310-bosch-3-0-curve-chart.html)
James Brown 12-13-2009 02:57 PM
Anyone know where I can find a gen-u-wine Bosch distributor curve chart for the 3.0L engine? Have a good idea what it should be but someone wants the real deal. any year will work.
Steve@Rennsport 12-13-2009 03:27 PM
James,
You'll find that in the Porsche factory shop manuals. They are different for US & ROW as well by year.
James Brown 12-13-2009 03:54 PM
Thanks steve. I'll pass that on.
mpetry 12-13-2009 04:30 PM
I have the factory shop manuals and found the distributor curves in section 9. See below.
I scanned the distributor advance curves for the 80 and 81 SC. The factory procedure for setting the timing is the same. -5 BTDC at 950 RPM with both vacuum lines connected. Given today's gas, I back this off to -3 BTDC.
As you can see, the high rpm slope in the advance curve is at about 3000 rpm SHAFT SPEED which is 6000 engine RPM (Distributor turns at 1/2 engine speed).
http://www.petry.org/pics/80SCDizzy.jpg
http://www.petry.org/pics/81SCDizzy.jpg
