84 3.2L swap in 77 Euro - Clutch issue
I'm (still) looking at a 77 Euro Carrera 3.0 that had an 84 US 3.2 installed ~20 years ago by the previous owner to the current seller. I have a concern about the clutch actuation.
The clutch is extremely heavy compared to typical SC's. My question is could a very heavy clutch be related to the engine swap, or is it very likely one of the typical causes, such as pedal cluster bushings, cable, etc.?
The seller states that the clutch has been heavy since he bought it. Seller installed new clutch 12K miles ago, but had no affect on the clutch actuation. Seller seems OK with it, but I know it's not right.
Any thoughts or comments greatly appreciated!
Old 12-13-2009, 07:31 AM
Is the helper spring missing, broken or detatched from the bottom of the bellhousing area? It looks like an "omega" near where the clutch cable attaches to the trans. I doubt bad pedal bushings would create that much friction. And he replaced the clutch so he's had two different clutches with the same problem.
Old 12-13-2009, 09:34 AM
Car is in another city, so it's not easy for me to check right now, but I hope that's all it is. Is it possible for a shop to go thru a clutch replacement and not see that the Omega spring is missing? I don't know exactly how visible it is.
Thanks!
Old 12-14-2009, 05:53 AM
I would look at the helper arm that has the big spring, frozen to the verticle shaft, really needs to be removed, cleaned and lubricated.
Bruce
Old 12-14-2009, 07:47 AM
Work in Progress
Rich76_911s's Avatar
I honestly think the helper spring did not come along until 1978 (the first year of the 911SC). I know my 1976 911S did not have a helper spring.
So that may be the reason the clutch feels heavier.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 12-14-2009, 07:59 AM
My '77 had an omega spring on the mag 915, and the PO removed the helper spring on the clutch pedal because he didn't like the feel.
'77 S with '78 930 power and a few other things.
Old 12-14-2009, 01:43 PM
