nineball's Avatar
door handle question
the po messed up one of my door handles and i am wondering about making a repair. the actual place the key enters on one side has been... well enlarged. the hole been widened to about 3x it's normal size, almost like someone tried sticking a large flathead screwdriver into it. the door still functions properly and i have had no problems but it is an eyesore and i would like to make it normal again. any thoughts?
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 12-14-2009, 04:33 PM
Cooper911SC's Avatar
You need a new stainless "face plate" or cap for the lock cylinder.
You can remove the door handle from the car and take it to a lock smith or the dealer for replacement. I'll bet the spring loaded "door" in the key hole is bungled up too.
(If you remove the cylider from the handle be SURE to insert the key first and leave it in or the wafers will fall out).
You may also be able to buy a used lock cylinder in good shape and swap over your wafers in the correct order.
Good luck, I've done several 914 locks.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 12-14-2009, 06:45 PM
nineball's Avatar
ya the "door" is gone. sounds like a bit of work is ahead of me. thanks.
Old 12-14-2009, 09:06 PM
