-   -   Header sizes for a 3.2 ---> 3.4 conversion, beating it to death... (http://forums.pelicanparts.com/porsche-911-technical-forum/516620-header-sizes-3-2-3-4-conversion-beating-death.html)
BGCarrera32 12-15-2009 10:50 AM
If you had a preference of a header primary size for 3.2 motor turned into a 3.4, would you run 1 5/8" or 1 3/4"? I don't want to choke off my higher rpm power, but it would be nice to pick up some low and mid range torque. Car is a street car that sees occasional DE use. SSI's are out, I'm convinced their tube dia is too small for the job.
Probably splitting hairs but worried about lack of backpressure, etc.
Thoughts?
BG
Tyson Schmidt 12-15-2009 03:01 PM
1 5/8ths unless you are turning 8500 rpm.
88-diamondblue 12-15-2009 04:36 PM
1 5/8 is what I am going to go with. I am planning on using the 993 heat exchangers as I want/need heat. Just about all the threads I have have looked at say 1 5/8 unless you have a really hot cam, then 1 3/4.
