-   -   1" HEIGHT GAIN/CORNER BALANCING (http://forums.pelicanparts.com/porsche-911-technical-forum/51667-1-height-gain-corner-balancing.html)
cab83_750 05-18-2001 08:44 AM
I just installed turbo tie rod and bump steer kit. I also recently had corner balancing,lowering and alignment done. After many hours and hard work, my mechanic finally gave me the # of the weight, and the height #'s were:
FR - 25 1/8
FL - 25 1/8
RR - 25
RL - 25
The car looked awesome at 25". However,
on my way out of the shop, "Stupid of me", pretending that I have money, I finally decided to also have four shocks replaced. I was told by the mechanics that with the new shocks, the height/balance will not be affected. However, alignment will be affected and will be adjusted accordingly.
Well, the car rides great with 4 new Bilsteins. But, SURPRISES! SURPRISES! SURPRISES. Now the height is as follows:
FR - 25 3/4
FL - 25 8/9
RR - 25 8/9
LR - 25 8/9
The car is now higher than before I took it in for lowering, and before the bump steer kit!
I was told that it would settle down soon and that if it does not, I would just come back and they'll lower the car again. I have driven over 150 miles and no settling is being seen. GUYS! Please provide input.
campbellcj 05-18-2001 08:46 AM
New gas shocks (Bilsteins) can increase ride height, particularly if they replaced old sagging hydraulic shocks. I suspect you'll have to lower it some more.
Chris Bunker 05-18-2001 12:10 PM
The Bilsteins are high pressure gas monotube shocks. They have a gas charge of something like 300 psi in them, which as you've experienced will raise your ride hgt. I was surprised at the height change I measured when I reconnected my Boge shocks (much lower pressure in a twin tube shock) after resetting the ride height.
Chris Bunker
78 SC
