Hey- Hey What's that sound ?
I have been working on a battery drain problem. I notice a distinct snap/click coming from the Alarm module whenever I reattach ground cable of my battery. Sounds similar to a relay. Is this normal ? If not ????
Old 12-16-2009, 08:54 AM
Not normal. The relay is what is draining your battery. On my car I have a horn relay but no horns. My horn button was stuck on my steering wheel and tripping the relay, draining the battery. You could just try pulling that relay if you don't need it.
-Andy
Old 12-16-2009, 04:03 PM
dshepp806's Avatar
Being that you've been working on a battery drain issue: What mA's are you pulling on your "drain test"?
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-16-2009, 05:10 PM
140mA with alarm powered. 40mA with alarm power or fuse removed.
Old 12-16-2009, 05:14 PM
