-   -   Heat exchanger interchangability? (http://forums.pelicanparts.com/porsche-911-technical-forum/516810-heat-exchanger-interchangability.html)
H Golf Sport 12-16-2009 09:02 AM
Quick question. Will a 3.2 stock heat exchanger setup fit a 3.0 SC engine?
Thanks.
Aloha, Rob
jason2guy 12-16-2009 11:53 AM
nope. you gotta mod the HE's. the lip or insert that protrudes into the head on the 3.2 HE's is too big to fit into the 3.0 heads.
H Golf Sport 12-16-2009 12:38 PM
Ok so aside from cutting off that lip the exchangers will line up and bolt to the heads?
Have you done this before?
Just looking for a quick fix for a friend.
Thanks.
palle7688 12-16-2009 02:23 PM
I've SSI's from a 911 SC on my 3.2, so yes the distance between the cylinders are the same.
But the flanges on the 3.2 heatexchangers are thicker and the bolts on you friends SC is not long enough.
H Golf Sport 12-16-2009 02:34 PM
Ok thanks for the replys. I think we can make this work.
snbush67 12-16-2009 03:11 PM
You can make it work but you will need the longer exhaust studs and cut the flanges of the HEs.
jason2guy 12-16-2009 03:29 PM
yeah itll work. you may already have the long studs, i did. to get it to seal up well i filed the gasket mating surfaces flat.
shbop 12-16-2009 05:05 PM
How about stock 3.6 exchangers on to a 3.2?
