-   -   Ticking Noise, not Rythmic (http://forums.pelicanparts.com/porsche-911-technical-forum/516901-ticking-noise-not-rythmic.html)
ruby911 12-16-2009 06:02 PM
I am picking up a ticking noise when driving my '84 Carrera that I cant pinpoint. The tick does not have a consistent rythm to it and does not do it at idle. It reminds me of the valve rattle you get in an american V8 when you run low octane gas in it. It seems to do it under moderate accleeration or constant RPMs while cruisng at about 3500 RPMs.
Any ideas?
christojen 12-17-2009 03:00 AM
I would get one of those auto stethoscpes and try to pinpoint the noise. Otherwise your description sounds a bit like pinging which is incorrect timing.
CJ
kidrock 12-17-2009 05:49 AM
+1, I agree it sounds like pinging. Can possibly be fixed by using a higher octane fuel.
Not to steal the thread, but if the pinging is caused by timing, what can you do to eliminate pinging if you have a DME-equipped car?
Also, can't pinging be caused by improper air/fuel mixture (lean condition)?
ruby911 12-17-2009 05:59 AM
I have always run the highest octane fuel available in GA and the ticking has only come on recently, so I doubt that is it. Could the ticking noise be an exhaust leak? I would think an exhaust leak would happen at all rpms and have a rythm to the ticking.
tshih 12-17-2009 06:21 AM
I recently had a problem with my 1988 Carrera 3.2 which was traced back to sparkplugs (specifically #6) which were improperly installed by PO to have backed up until #6 was out of the socket! I was running on 5 cylinders. When I put in new sparkplugs and did a valve adjustment check everything runs like they're suppose to.
T77911S 12-17-2009 06:59 AM
if it is pinging or spark knock, then timing or something making it go lean. air leak?
BReyes 12-17-2009 07:22 AM
Mileage? Visual inspection ok? Ignition tune up ruled out? When was last valve adjustment? How are the valve train components, tensioner, ramps, chains?
Regards,
Paulporsche 12-17-2009 10:34 AM
Are you sure it's from the engine? How about a stone in the tire tread?
ruby911 12-18-2009 07:55 PM
I am doing valves this weeked and am curious if I will uncover anything 'interesting'. We'll see what happens...
I would think stone in the tire would be very rythmic.
Hugh R 12-18-2009 08:08 PM
Plug wires?
s5uewf 12-19-2009 04:12 AM
is it possible a rocker adjustment bolt has backed off a bit?
jderrick 12-19-2009 08:23 AM
Perhaps the following link can point you in the right direction.SmileWavy
http://forums.pelicanparts.com/porsche-911-technical-forum/246871-ticking-sound-dashboard.html
Regards,
John
ruby911 12-20-2009 06:37 AM
definately not comnig from the dash, it is from the engine bay. Valves are being adjusted right now. The idea of a head stud fallibng out when the valve covers are removed is a notion that keeps entering my brain - I keep pushing that notion back - dont want to think about that right now....
sc_rufctr 12-20-2009 06:43 AM
Based on you initial description I suspect a broken valve spring.
ruby911 12-20-2009 06:51 AM
thanks all for the feedback, fingers are crossed.
E Sully 12-20-2009 09:18 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/517006-85-911-strange-noise.html
Check this link. Throttle body deicing valve by the oil tank can cause a rattle when it is bad.
ruby911 12-21-2009 05:49 AM
valves adjusted and problem solved. Thanks all. Damn she is running good!
