Installng a remote starter switch this weekend
I have been wanting to do this for a long time. Right now I either have a spark problem or a fuel problem. This way if she dies I can cheak for spark. Also it will double as a compression cheaker a points bumper and who knows what else. I plan to attach it to the fuse panel in the engine compartment.this will be a permanent install..Has any body else done this ??Wayne 72 911S sunroof
Old 11-09-2001, 08:37 PM
Shakenbake's Avatar
How do you plan to do this, give us the details. I have seen remote starters used but never permanently wired to the fuse panel.
Shakenbake (Chris Baker)
Need new toys
2001 VW Jetta VR6
2003 Sea Ray 200 Bow rider
Old 11-09-2001, 08:54 PM
Early_S_Man's Avatar
Chris & Wayne,
Extremely simple to do on MFI & CIS cars, if you remove the relay/fuse/CDI panel from the fender mounts ... as both the Yellow #50 lead to the solenoid, and the Red B+ lead from the alternator are there to be tapped into! The rear 14-pin connector to the engine wiring harness has both leads you need, on pins 1 and 14. All you have to do is find a convenient location for a momentary switch, and then run wires to the red and yellow leads!
If you look at the following diagram at the lower right quadrant ... the circled #84 connectors, it is all there for the partaking:
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1973_CIS_Part2.jpg
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-09-2001, 09:18 PM
Well I did it!! Thanks Warren on the tip for term 1 and 15 . I put the marine push button starter switch in one of the holes that is not being used for a relay in back panel.tapped into the lines Hard Part! and mounted the switch. The push botton starter switch was completly insulataed rubberized. With out Warren suggestion I was going to wire into the starter and siliniod..
Old 11-11-2001, 08:57 AM
ebradway's Avatar
Cool! I had a 1980 Toyota Corolla SR5 in college (the last really good Toyota until the MR2 - rear-wheel drive, carbuerated). The starter switch died and I didn't have the $75 for the new part but I had the $10 for a couple toggles and a 'big red button'. I left the key in the ignition to keep the steering wheel unlocked (didn't want to break the mechanical part of the switch).
I loved jumping in the car, flipping a couple toggles and pressing the button. I've been thinking about doing the same thing in my 911. Honda did a wonderful thing by putting that big red button on the dash of the S2000. I want the same thing on my 911!
Oh yeah, when I do it I'll still require the key for the 911. I never worried about someone stealing my rust-and-primer 10-year-old Toyota with 240K miles on it - but my 15-year-old 911 is another story even if the miles are close!
-Eric
Eric Wolf
Old 11-11-2001, 09:12 AM
