Scott R's Avatar
Clutch noise
I'm about at the end of 911 ownership after today. I needed my SC since one of my other cars is down for maintenance. Anyway, clutch in I get a rattle from the tunnel, clutch out in neutral I get nothing. Shifts perfectly through all gears.
The 915 is a fresh professional rebuild I think less than 1k miles on it. Clutch is new, it's a Pelican SACHS kit, same mileage as the transmission. Everything was balanced during the engine and trans rebuild, flywheel, clutch, plate.
Am I losing my TO bearing? Should I stop driving it? I've had a few fun miles when the weather was nice recently, and now that the carbs and ignition are done it's a nice ride. I just hate to tear it all down again for nothing. I'm hoping one of you guys will say it sounds normal.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-21-2009, 03:12 PM
I'm here to cause trouble
jimbauman's Avatar
FWIW, here's my opinion.... I had the same noise for a couple of years... decided to do my clutch one weekend because it had 75K miles on it and i do LOTS of track events.
I replaced everything except the TO bearing (don't ask why.. it just worked out that way ). Anyhow, I put it all back together, perfect clutch, same noise. I just ignore it. I have solid engine/transmission mounts so the noise is probably worse in my car...
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 12-21-2009, 03:19 PM
Scott R's Avatar
JB
Thanks for the reply, I'm going to just drive it. Enough with this constant tinkering that I'm doing.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-21-2009, 03:30 PM
