shifter slop?
in my '70T with a 901 (911) 5-speed transmission, the shifter action is not exactly precise. the shift-lever action is mushy if you will. the throws are very long, i am thinking about getting a short-shift kit, but will that most likely clean up the mush? if i replace the shift bushings with urethane bushings, will that help? i'm looking to make it so the shifts are more precise, will the combination of the short-shift kit help alone? thank you!
I would START with the shift coupler located under the access cover which is between the seats. A cheap item compared to other items, that is if a 70 has this-my 72 does-hmmmm
72 911 Although it is done at the moment, it will never be finished. |
Friend of Warren
Start by reading this Pelican Tech Article: http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
Kurt V No more Porsches, but a revolving number of motorcycles. |
