Hours
Hello,
I'm about to have the cylinders removed, refurbished and reassembled. Does anybody have an idea with how many hours I should count to: Drop the engine Remove cylinders Remove piston rings Install piston rings Put everything back together Re-install engine and adjust Refurbishment of cylinders and cylinder heads will be done at a specialized company for a fixed price Thanks, Ed |
Youre doing the rings but not a valve job? Why would the rings be wasted and nothing else?
Youre looking at about 20 to 25 hrs Bruce |
Thanks, of course will be complete top rebuild. What I meant is that one workshop will do the disassembly / assembly while a specialized company does the cylinder head overhaul etc.
