Question %#&@ ball joints
How do you remove a ball joint that does not want to leave? I have tried the special socket and even tried using a hammer and punch. The problem is that it bent my punch! Since I planned to have them rebuilt anyway, am I better off just replacing the a-arms?
Thanks,
Rich
Old 11-11-2001, 05:52 PM
Not Quite Banned
Thomas Owen's Avatar
Try heat, then apply liberal dose of hammer.
Thomas Owen
1972 911T
1972 911S
Old 11-11-2001, 06:16 PM
cwood
Guest
Posts: n/a
1. Use the socket
2. Use a impact gun
3. The nut is torqued to about 184 ft-lbs
4. Most people have a hard time pulling that much torque (OB's etc).
So go the air route no muss no fuss
Old 11-11-2001, 06:51 PM
tobluforu's Avatar
If it's still bolted up to the car, you should be able to break it loose with a breaker bar. Not sure what to do if it's off unless you have a nice vise.
Old 11-11-2001, 07:43 PM
Author of "101 Projects"
Wayne 962's Avatar
Place a jack under the special tool and apply pressure from the botton - keeps the tool from coming off. Then muscle the heck out of the thing.
if that doesn't work - use a dremmel tool to cut the nut off. You're replacing the ball-joint anyways, and the new nuts aren't that expensive...
-Wayne
Old 11-11-2001, 07:55 PM
hank911's Avatar
m-pact,air!! or just destroy it!
Old 11-11-2001, 09:02 PM
