-   -   2.2S teardown (http://forums.pelicanparts.com/porsche-911-technical-forum/517864-2-2s-teardown.html)
BK911 12-22-2009 10:33 AM
2.2S teardown
I have been slowly tearing down a 2.2S engine. I was told this engine was sitting under a tarp since 1972 and had only one year of year since new. Here are some pictures. Please tell me if you think the engine could have been as described.
I am not sure what I am doing with it yet. It may end up in my 73.5T as a high compression 2.4S, sorta a 2.4S+.
The throttle shafts are just TIGHT. I need to take them apart to lube them up. NO slop at all.
http://forums.pelicanparts.com/uploa...1261506342.jpg
Check out the gear on the pump. I dont see any wear. Cam gear looks the same.
http://forums.pelicanparts.com/uploa...1261506383.jpg
Cam lobes look perfect. I didnt even wipe them down.
http://forums.pelicanparts.com/uploa...1261506433.jpg
Rocker arms look as nice
http://forums.pelicanparts.com/uploa...1261506468.jpg
Cylinder looks pretty good. very little wear. I will mic it of course, but looks good so far.
http://forums.pelicanparts.com/uploa...1261506675.jpg
Heads were only wiped down with a rag. I will dis-assemble but look good so far.
http://forums.pelicanparts.com/uploa...1261506743.jpg
I haven't split the case yet, but I like what i see so far. To my untrained eye the engine looks as advertised so far.
I would appreciate the feedback from those that know more. Whadda you think?
Thanks!
GaryR 12-22-2009 12:20 PM
Looks pretty new to me, unless the cyl cross hatch isn't factory?
Peterfrans 12-22-2009 12:24 PM
The rocker shafts have rsr seals in them, not something you would see in a factory engine. Also the rockers arms seem refinished, normally they have a fairly sharp edge, which in this case seems broken. In any case an interesting find
Rusty 356 12-23-2009 02:58 PM
When did Porsche stop using forged rockers in their "S" motors?
