How to Recharge a Deeply-Discharged Optima Battery
fintstone asked me to start a thread with instructions on how to recharge a deeply-discharged (below 10.5 volts) Optima battery.
Virtually any standard automotive battery charger on the market will charge an Optima battery just fine. However, most automotive battery chargers will not charge any battery that has been discharged below 10.5 volts. If a standard flooded battery is discharged below 10.5 volts, there’s not much of a chance that it will be serviceable again. However, AGM-style batteries, like Optimas, can be recovered from a deeply-discharged state, by using an AGM-specific charger or by parallel charging. To charge a deeply-discharged Optima with a regular charger, you can wire a second fully-charged automotive battery (12V+) to the discharged Optima in parallel (+ to + and – to –). Then hook up the charger to either battery, setting the charger at 10 amps for 2 hours and monitoring it frequently. ![]() When the discharged Optima reaches 10.5 volts or more, remove the second battery and continue charging the Optima until fully charged. Typically we recommend charging at a relatively low current, such as 2 amps, but when a battery has been deeply discharged, some sulfation of the battery plates may have occurred. However, if you charge at 10 amps, the higher current will help to break up sulfation that may have occurred. If you have an automatic charger, let it run until the charger indicates charging is complete. If you have a manual charger, estimate charging time by multiplying the capacity (amp hours or Ah) of the battery by 1.2 for a rough estimate of charging time in hours. In most cases, these steps will recover an Optima battery. It’s ok for the Optima battery to get slightly warm during the charging process, but hot to the touch or hissing from the battery indicates a short and the process should be discontinued. If you are able to fully charge the battery, but it gradually loses it's charge (without any loads on it) over 12-24 hours, the battery is probably not recoverable. If you’d rather not deal with this process, you can always take your battery to a professional battery specialist, like Interstate, who knows AGM technology. Most of them are willing to provide “charge and check” procedures for a small fee and many will provide the service for free. If you have any other questions, I’ll do my best to answer them. I appreciate your interest in Optima batteries! Jim McIlvaine eCare Manager, OPTIMA Batteries, Inc. Last edited by OptimaJim; 12-28-2009 at 10:28 AM.. Reason: clarification on charging instructions |
Thanks for the info. The first Optima battery I have purchased is for my Porsche. Good info to know.
76 911S Targa An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage! |
If you parallel a discharged battery with a 'charged' battery, there will be a large surge of current from the 'charged' battery to the 'discharged', correct?
Jim, can you tell me the difference in Optima batteries from 10 years ago, and those made today? Frankly, I bought some in the mid-90's that lasted 6-7 years+ and were still going when I sold the car(s). Last few Optimas I bought haven't lasted 1 year without issues. Last edited by dad911; 12-23-2009 at 08:53 AM.. |
what about the regular (not in this group) guy with only one car? i have read threads about hitting the dead battery with the "start" mode of the battery charger for a few minutes (hours?) to wake it up...no bueno?
1981 white 911SC coupe "Betty Whitey". |
I always JOLT my Optima from another car or the start mode and then put it on trickle charge 2amps until fully charged. It seems to work, is this ok? Although the best is to leave an automatic trickle charger on it when out of use for more than a week.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Free bump from a very happy Optima customer.
3 in the toys. 1 in the emg. generator. 1 red top is 11 years old and going strong!
pozee |
Thanks Jim! So basically one needs to connect the optima to a standard battery with jumper cables and then connect the charger to the standard battery.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Don't you mean "hook up the charger to the Standard Battery, setting the charger" at 10 A for 2 HR... ...as the diagram shows? Last edited by tcar; 12-23-2009 at 01:22 PM.. |
doesn't matter, being that they're hooked up together.
yes,..together (paralleled).
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Edition Middle Georgia |
wow, my hats off to you. to think i recycled all the Optimas when they got too low! wow! and i have been through some batteries!
I have two dead ones in the garage that I will try this with. I paid so much for them I couldn't bring myself to turn them in as cores. Now I am glad I didn't
Thanks again Chad
09 Cayenne GTS: GTS red, race car tow vehicle 86 Porsche Carrera, GP White- E Class PCA Club Race Car 71 Porsche 911T Targa, Silver, Sport seats, 2.7RS spec motor. 90 Porsche 928 S4 w/ 37K miles Grand Prix White/ Cashmere 73 Karmann Ghia Cabriolet, Black, 1776 Turbo, 250hp |
tcar, thanks for pointing that out. I did edit my original post to clarify the instructions. You can hook the charger up to either battery, as long as they are both connected in parallel.
dad911, I'm not sure what you consider "a large surge of current," but we recommend no more than 10 amps for Optima batteries. Some battery chargers cannot detect batteries that aren't at 10.5 volts or more. Parallel charging allows that to happen. I'm not allowed to discuss specific improvements we make to either our batteries or our production process, but when we do make changes to either, we do so to improve the end product for our consumers. One thing that has changed over the last six to seven years is an explosion in the use of aftermarket electronics, like mp3 players and GPS systems, which will put an additional draw on any battery, if they are left plugged in when the vehicle is parked. No battery manufacturer has figured out how to achieve a 100% success rate in their production process. However, if your vehicle has had more than one battery fail in less than a year, there may be some other issues contributing to those failures. vash & RSTarga, there are a wide variety of chargers on the market with a variety of settings. Charger A's "start mode" might have totally different settings than Chargers B, C and D. Some chargers have "gel" or "gel/AGM" settings, which should not be used on Optima batteries and will damage them over time. As I mentioned before, virtually any standard automotive battery charger will charge an Optima that reads at least 10.5 volts. If you are looking for a battery charger or a battery tender/maintainer it is very beneficial to get one that is microprocessor-controlled and has "AGM" compatibility. If it has a separate setting for AGM batteries it will enhance the battery’s performance and potentially extend the life. In addition, make sure that the device has protection to prevent overcharging. Since there are many great battery maintainer/chargers on the market, we do not have the capability of testing each one. We do not “officially” endorse specific maintainer/chargers, but we will supply information about devices that are advertised as being compatible with AGM batteries. Here are a few: CTEK MULTI US 7000 or 7002 CTEK battery charger - US 800, MULTI US 3300, MULTI US 7000 Interacter EX (12 volt 6 amp model) EX Wall-Mount Charger PulseTech Xtreme XC100 XC Xtreme Chargers | Xtreme Charge I appreciate your interest in OPTIMA Batteries! Jim McIlvaine eCare Manager, OPTIMA Batteries, Inc. |
deRegistered User
Thanks Jim - that is very helpful!
- I am going to change my batt. maintainer to an AGM type that you listed.
When you reduce the vehicle weight, “you get more performance with less of everything.” – Alois Ruf, quoted in THE ESSES (Early 911S Registry Bulletin) Fall 2005, 15(3): 3. |
When you parallel a fully charged battery to the discharged Optima, there will be a large surge of current, certainly in excess of 10 Amps. In fact, standard practice dictates dissimilar batteries should not be paralleled, only like batteries with similar charge. I am not talking about a car equipped with 'new' devices. I have track cars, battery is disconnected through a cut-off switch between uses. In 2 recent occasions, Optimas have lasted less than a year, when in the late 1990's I got over5 years from one. |
Since we're talking batteries, funniest battery commercial ever:
Battery maintainers/tenders are an excellent investment for vehicles that are stored for any period of time. Even if these are not used, it's a good idea to check the voltage when vehicles are put into storage, to ensure that batteries are fully-charged and then periodically check the voltage during storage, to make sure they maintain at least 12.4 volts. Jim McIlvaine eCare Manager, OPTIMA Batteries, Inc. |
Jim, If I can demonstrate that when you put a charged wet battery in parallel with the discharged Optima, the charging current(surge) from the wet cell to the Optima will exceed 10 Amps, will you send me (2) Optima batteries to replace the 2 I have that didn't last?
However, if the discharged battery was also defective, i.e. shorted cell, then the internal resistance will be abnormally lower and allow more current to flow through it and perhaps cause further damage and heat. My take on it. Sherwood |
