horn relocate
What does the horn relocate kit looks like. I added back my horns but my oil cooler fan was too close so i had to modify the way the horns were attached The modified mount is not as substantial as porsche design but it there for now. any takers?:
Horn relocation for oil cooler
I used the original steel horn mounts, bent them flat and then re-attached everything , this extended the horns far enough forward to clear the cooler and fan. It actually worked so well that I did not need to use the horn re-location mounts. Sorry I don't have any pictures, good luck.
Dennis |
