What fire extinguisher ya'll carrying?
Just wondering what fire extinguishers ya'll are carrying in the cars and where mounted. I've got single halon one to carry between a few classic cars I own. I was going to buy more, but they're pricey and not good for the environment. What are the alternatives? Does anyone know how the First Alert Tundra does for automotive use? Will it mess up electrical and metals like the dry chemicals one do?
Thanks!
Old 12-25-2009, 10:20 AM
Green 912's Avatar
Halon works well does not leave any residue and is far less expensive or bad for the environment than burning your car to the ground.
Old 12-25-2009, 10:29 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
I have a halon bottle and fab'bed my own mount from 1" aluminum angle. Just as good as the brey-krause mount and $200 cheaper.
Mark Petry
Bainbridge Island, WA
81 SC
Old 12-25-2009, 10:43 AM
Drew001's Avatar
Send a message via ICQ to Drew001 Send a message via AIM to Drew001
I'd still be interested to see if the Sparco Fire Eater is all it seems to be.
Expensive, yes, but 51 seconds of delivery in a very small package.
It doesn't seem to be available in the US though.
Info:
The Sparco Fireater is a flame inhibitor which works by saturation, particularly effective in more or less closed environments such as the engine compartment or passenger compartment of a car.
Its revolutionary technology, developed for the Soviet space stations Soyuz, is based on the use of a potassium salt and pyrotechnic rubbing primer which produce a gas that escapes from the shell and suffocates the flame.
It offers numerous, sensational advantages compared to a traditional extinguisher: reduced size: length 270 mm, diameter 30, weight 250 gramsno maintenanceno residue after usenon pressurised contents, may therefore be shipped by plane thanks to its declassification to non exploding product (Prot. N° 04003546 – 1/30/1 Area 1/Bis)51 seconds of delivery, against the approximately 10 seconds of a 1 kg powder extinguisher.
The Fireater is classified in class 8B, and can therefore be kept inside the car, since European regulations (ECE), require a minimum of class 5B.
Old 12-25-2009, 08:16 PM
Mitch Leland's Avatar
Do most folks use the 1.4 lb bottle?
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 12-25-2009, 10:00 PM
Anyone know anything about the First Alert Tundra? Inexpensive and supposedly easy clean up... also longer spray time than regular extinguisher.
Old 12-26-2009, 08:24 AM
Soldier of Fortune
DasBoot's Avatar
The Tundra doesn't appear to be rated for automotive use (oil/gasoline):
First Alert Launches Easy-To-Use Tundra Fire Extinguishing Spray to Extinguish Fires - OutdoorReview Forums
Old 12-26-2009, 08:36 AM
iamchappy's Avatar
No reason not to be over protective.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 12-26-2009, 08:42 AM
Halon
I also have this one , more eco friendly HFC 236 fa
Old 12-26-2009, 11:03 AM
