-   -   Quick: Identiification of Boge Insert (http://forums.pelicanparts.com/porsche-911-technical-forum/518233-quick-identiification-boge-insert.html)
Lukesportsman 12-25-2009 06:38 PM
Here is what I have. Two sets of Boge: 1. set just took off car presumably stock Boge's 2. Set of Boge's recently supposedly rebuilt with custom tuned Bilsteins.
Question: Do I presume that since the collar nut is different and gold coated on the rebuilt Boges that I do truely have the Bilstein inserts. The rear that came with susp package included Bilsteins and everything is poybronze and top notch. That being sad, other than just installing and seeing is there a way to identify strut insert without removing and measuring diameter?
I can't raise the spindles on a Boge can I?
DRACO A5OG 04-18-2010 10:12 PM
Sorry for the slow reply, what is the part number? if it is Heavy Duty, you will see ...P360114HO. There should be a part number.
