Bent Engine Cross Bar
Hi,
I'm in the process of cleaning up all the pieces on my engine prior to putting it back in. I was cleaning the rear engine mount(cross bar + mount console) and noticed that the bar was pretty well bent. What are your thoughts? Is it worth it to hammer it back to straight? Should I just get a straight used piece? Pictures: http://forums.pelicanparts.com/uploa...1261957838.jpg http://forums.pelicanparts.com/uploa...1261957902.jpg http://forums.pelicanparts.com/uploa...1261957957.jpg http://forums.pelicanparts.com/uploa...1261958202.jpg |
Some engine mounts are threaded, and some use a through bolt. If this was threaded, it looks like it was torqued upon removal?
Inspect the welds, but I would either replace it or straighten and reinforce it. |
I think it would be best to find a straight used part. Just my. $.02 :)
I would replace that one too.
Used Porsche Parts shop order placed.
Thanks! |
There's little to counter-hold the end of the mount bar while removing/replacing the engine mount bolt, so it was probably bent when the engine was removed once upon a time. If you can straighten it, fine, but either way, I'd suggest drilling out the existing threads and use a through bolt, washer and nut; same as the orig. motor mount bar in '73. The later motor mount bar uses just a threaded bolt into each end.
Sherwood |
| All times are GMT -8. The time now is 04:32 AM. |
