Window regulator pivots
Where is the best source for these? Tweeks, Performance, or ??? They seem to be spendy....
JW Denver, CO |
if pelican doesn't have them, performance does. not cheap for what it is, but real cheap in the long run, compared to a new or used regulator. they're also steel, so they're tougher than the original aluminum ones, and you can put a spot weld on the back for extra insurance.
spot weld ...
Do you mean a spot weld on the notch to strengthen it? or....?
Thanks for the reply-- JW |
no, on the back, once it's been swaged in.
Ahhh. Thanks for the tip--
JW |
| All times are GMT -8. The time now is 01:48 AM. |
