82 911 broken head studs what to do ???
Hello everyone I am new to these forums so let me know what to do I have a 82 911sc with a 3.0 and I bought it with motor problem it was leaking oil into the Exhaust and I though it needed new rigs so I poled the motor and in the middle of the tar down I notes its has 2 broken head studs and is it common with these Porsche and how can this happen???? Is it easy to fix this or do I have to get a know motor so let me know what to do thanks
1982 PORSCHE 911 SC ![]() 1973 PORSCHE 914-6 WITH V8 ![]() 2003 VW GTI |
Yes it is very common....no you do not have to replace the motor...however it is fairly expensive to have repaired. There are a lot of variables. When I had mine done I replaced the studs with ARP brand....they are pretty much bullet proof. The issue is with the materials the original studs were made of. The heat cycles over a period of time weaken the exhaust studs causing them to break. Most likely with only two broken studs no other damage was done. The nice thing is you were going to have to pull the pipston/cyl anyway to replace the rings...so basically if you can get the studs out while you are at it the only extra cost is the studs. You have several options as far as the quality and material and price of the studs are concerned. If you do a search for head studs you will see that you are far from being alone in this matter.
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
I have a 82SC that had 2 broken studs also. The lower studs corrode and weaken to the point that heat cycling will snap them. Mine snapped in the middle so I was able to remove the 2 broken as well as the other 10 bottom ones with heat. The upper studs are steel and do not have the same problem as the delivar bottom studs. Do a search as many have posted about this topic and you will find many options and information on replacement. One common fix is to replace the 12 lower delivar studs with 12 steel upper studs, depending on your situation this can save you hundreds of dollars.
82 911SC 74 MGB 97 Land Rover Discovery |
RETIRED
Replace them all with steel studs, I like Raceware. Don't screw with the bottom end, get a new gasket kit from Pelican and consider a valve and guide job. If you haven't removed the exhaust nuts on the heat exchangers yet...do a search on that BEFORE attempting to remove them.....they can snap in a NY second.
BTDT and it's a beyotch to get a flush snapped stud out. Last edited by Joe Bob; 12-29-2009 at 06:49 AM.. |
Somatic Negative Optimist
Good advise.
sesco: I hope you get Wayne's book on 911 Engine Rebuild. Send the heads out for a Valve job, guides and seals. Replace the head studs with steel. Gasket kit from PP. If you remove the heat exchangers, be very careful when removing the nuts for the exhaust studs. YOU NEED RED HOT HEAT! Do a search here for this. Get Wayne's book; it's the Bible.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
thanks guys its weard that the car only has 27xxx and is there some one in michigan that i can send the motor to and add some performance parts
not that odd it is almost 28 years old and are you sure its 27k miles ? also Michigan weather isn't very car friendly, its not the end of the world but its gonna take a bit of work , if you can do it yourself not real expensive , at a shop not so not expensive . best of luck , unsure why they do go , some do some don't mine 1980 knocknock ni issue yet at 165k and climbing ..... best of luck
my understanding is that low mileage doesnt mean that you are less likely to have broken studs.
moisture gets at the studs and if it sits alot (28k miles in 25 plus years) that moisture had time to soak in. its didnt get burnt/evaporated off. i had 2 broken studs earlier this year. california car with 77k miles. i took it to a shop to have the repair done. in retrospec i wish i had done the repair myself good luck to you
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
I have an 87 Carrera with 130k and had a head stud break. Got engine on a stand and got in over my head FasT. Porsche engines are very different and unforgiving for a shade tree like myself. Ended up in a Porsche mecahnics shop in N.C. Car back on the road
Grab several thousand $ out of your bank account to do this properly, unless you do it yourself, then it is only a few thousand $. Not for the weak of wallet.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Step #1. Buy Wayne's book.
![]() Lot's of bad experiences out there. ![]() If I were you, I'd ask around by starting a new thread here on PP asking for recommendations for a shop in your area. It's worth it even if the shop is far away, or in the next State. ![]() You can drive the car to the shop but I wouldn't continue running the engine until then.
Ambitious Outsider
1988 3.2 Cab 2005 997.1 C2S |
I had 7, yes 7 broken head studs. Found a really good Porsche shop and did a top end rebuild. You want this done right.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
thank guy iam going to buy a Wayne's book an do it myself or try it myself think guy
Good Luck.
I had a broken stud too. Buy Wayne's book and take your time. I thought it wouldn't be a big deal since I use to build aircraft engines. Wrong!! Be sure and pay attention to valve timing and rocker shaft installation. Valve Timing is no big deal if you use Wayne's book. The rocker shafts gave me grief. I torqued pinch bolts according to Service Manual. They need to be torqued to 18-20 ft lbs. Also, buy the recommended rocker shaft $eals. In my situation, i fixed a couple of oil leaks since the motor was out. But created a few more that were leaking from the rocker shafts on to the header. So I am getting good at dropping Porsche engines. Ed Garcia 1977 Carrera 3.0 |
I bought the Wayne's book, too. Started pricing all of the special tools needed, around $500. I subtracted that from labor charge and feel I came out good. I sent the injectors to have rebuilt. I think the car runs better than it did when I bought it with 70k miles. It won't sit in a storage bldg again. Good Luck! You have the best of the best on this forum to help you out!
Used Up User
It is often low mileage cars that have broken head studs. Corrosion is the culprit & sitting for months & years with no lubrication is not good.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
How do head studs get lubrication? Isn't it the heat cycling that burns off moisture and prevents rust?
grateful user
cesso, I went through this last summer. It could be very easy, are the worst experience you will ever have. I would try and get the lower ones all out, the top ones are steel already, and should be fine, there is nothing wrong with a used steel stud, as long as its not corroded. Being you are from Mich, i bet you are going to have fun getting the studs out. You can search my thread "need help on broken stud" to give you an idea what could happpen if one wont come out. On my thread, one of the Pauls gives insight to a special snap on tool stud remover, i would check that out.
![]() ![]() ![]() as posted above, if funds are available, get the valve job, cams, new springs,and fix all your leaks while you are in there, (about 2500.00)
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
