-   -   Amount of threads per page... (http://forums.pelicanparts.com/porsche-911-technical-forum/51880-amount-threads-per-page.html)
beepbeep 11-12-2001 03:17 PM
...should be more than 25 as it is now.
Lot's of good threads disappear just beacuse people don't care for pressing "2" for second page...
Example: very good on-topic "CIS vs. EFI" thread dissapeared on page two and will probably stay there..."out of sight, out of mind".
Raising number of threads on page will prolong thread-exposure time and raise thread to post ratio, thus lowering signal to noise (OT) ratio ...
It's possible to adjust number of posts per thread-page in user settings , but not number of threads per main-page. (At least i didn't find a way).
Most other UBB-forums have more threads per page than this one. 50 seems to be usual choice. It does strain SQL-database little more, but i think it's worth it.
Opinions?
tight as a bull's ass 11-12-2001 04:11 PM
yeah you're right. As a thread slips into the 2nd and 3rd pages, it becomes more likely that it disappears into the past.
I looked around and found no setting to change this....maybe the BBS administrator can change a parameter to allow more threads per page.
Emmanuel
83sc
http://www.basementouttakes.com/
info@basementouttakes.com
josh912 11-12-2001 05:49 PM
You can change it under the user options.
tchanson 11-12-2001 07:42 PM
Josh,
How do you change it in the user options? As noted above, I also couldn't locate anything under Edit Options that would allow a change beyond 25 threads per page.
You can change the "default thread view" (I changed to "last day") but the display still shows only 25 threads per page. I also agree that 50 would be much better than the current 25.
Thanks,
Tim
josh912 11-12-2001 08:18 PM
I guess that isn't the way. I tried the change the default view and nothing. Hmmmm, Wayne????
Wayne 962 11-12-2001 11:55 PM
Changed.
Wayne 962 11-13-2001 12:37 AM
http://www.pelicanparts.com/ultimate...choice_tag.gif
Also added support for multiple image posts as requested by Clark Griswald!
-Wayne
