Compression & Leak Down tests on cold engine. . .
Hi -
Just a quick question. . . is doing compression & leak down tests on a cold engine a complete waste of time? If an engine is not installed in a car and unable to be started to warm up, what is the best way to determine it's condition? Thanks, Tom |
you can do it and you may get a decent result, but it would likely be better if everything was oiled and expanded from heat.
| All times are GMT -8. The time now is 06:23 AM. |
