round electrical connectors? - part number or availability
the online PET is down so I can not look this up.
Is the standard multi-pin round electrical connector available? I am referring to the one used for tail light and turn signal housings; as well as the underdash and some early engine bay connections. This is not the same as the 5-pin relay connector. I am looking for a part number or any additional information. More specifically I am looking for the tail light connectors for a custom application. |
Jamie,
As they are molded over already terminated wires I believe they must be considered part of the harness and doubt anyone stocks a replacement. For my custom wiring job I had to cut and splice used ones; very tedious. regards, Phil |
Phil, I thought the same thing. I was hoping to not scrounge the dismantlers for these parts. I don't mind splicing if i can find the correct parts.
wiring
Hello, If you can send pictures of what you need I usually have them. I rebuild 914,924/44,928 - The wiring is all the same SmileWavy
| All times are GMT -8. The time now is 03:15 AM. |
