AFD660's Avatar
Protective paint for interior
I was curious as to what people use for pretection of the floor pans after they remove the black sound deadning material from the floor of their 911. I think I remember seeing some people use a brush on paint. Im not sure if it was from Wurth or Einzett. But I guess it was to prevent corrosion and what not. thanks
Jonathon
Old 01-02-2010, 10:25 AM
AutoBahned
RWebb's Avatar
I just use a Rustoleum primer & then brush on their top coat - above that a brush or roll on sound 'inhibitor' the kind with the micro-ceramic beads. Then, I'll put in new carpet & foam padding.
That is a low buck way to go for an area that is covered anyway.
Some have used powdercoat and many have used an encapsulating epoxy mix.
Old 01-02-2010, 01:48 PM
