byfdinky's Avatar
WOW! I don't know if I'd have time, money or ambition for a project like that!
My car had no rust and still broke me with upgrades and repairs!
-Bill
1979 911 SC Targa
Old 03-01-2010, 06:48 AM
signature65's Avatar
I was right there with you too.....my rear parcel shelf was nothing but fiberglass bondo. Such a mess but now replaced and all is right in my porsches world!
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 03-01-2010, 08:39 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Originally Posted by blee View Post
I am, but the regulator has been giving me troubles, it seems intermittent? Is it that ugly?
No, it just had the look I get when the Argon isn't flowing or i'm too far away with the tip. It's fine, be proud of what you are accomplishing!
Gary R.
Old 03-01-2010, 08:52 AM
Registered?
blee's Avatar
Tip closer and check the Argon flow - got it! Thanks Gary. The metal is so thin, I'm afraid I'll blow holes if I get too close or stay on the trigger. I need to practice on some scrap pieces before moving forward.
Brian
R Gruppe #787
70T Ex-Waterlogged Rust Bucket
http://forums.pelicanparts.com/porsche-911-technical-forum/519605-waterlogged-rust-bucket.html
Old 03-01-2010, 09:33 AM
digitaldgp's Avatar
Subscribed, I have a 1970T with similar issues, they are a labor of love.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 03-10-2010, 08:33 PM
Registered speed offender
78SCRSMAN's Avatar
Just an offer for advice. If you don't already have one. Go to Harbor Freight and get an instant-on welding helmet. It will be the best $40 you'll ever spend... I promise. Then you can be on and off the trigger as much as you need and believe me, you don't want to be on it continuously, you will simply blow holes through the metal. At the same time, you want to get good penetration, (still talking about welding here) which means lots of heat. So enough heat to ALMOST blow a hole, then stop for a second or two, trigger again, repeat as necessary.
It looks like you got your hands full, good luck!
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 03-10-2010, 09:00 PM
Registered?
blee's Avatar
So much for the first weld - it was rubbish I tell you! Found a bunch of pinholes after applying primer. Had to go back and re-weld until all the pinholes were gone. Turning the power down on the welder helped too.
It doesn't look like I'll have to cut the rain chanel on the driver's side?
And, as expected, found more rust and fiberglass in both rockers. Doesn't look too bad though, I might be able to get away with patches instead of replacing the whole thing. (it seems for now anyway) The journey continues...
Brian
R Gruppe #787
Old 03-16-2010, 08:26 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
Really curious about how you're gonna solve that issue with the rockers. Our '67 has the same issue right now
'75 911S 3.0L
'75 914 in progress
'67 912R-STi
'99 LR Disco 2
Old 03-17-2010, 06:59 AM
300hp 1800lbs is the goal
pksystems's Avatar
The inners look nasty too. Spotweld cutter and new outers/inners..... I have sets waiting to go into my car too. My car looked pretty good.... till I ground like 1/2" of bondo off the rockers, and could see the inners
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 03-17-2010, 10:12 AM
3 restos WIP = psycho
kenikh's Avatar
Careful with cutting too much at once. I know it seems like an oxymoron, but the rsuty panels still lend some rigidity to the body. Cut too much out and you'll wish you'd welded in a body jig. Take it slow, replace one piece at a time, ensuring one repair doesn't get in the way of the next.
Good work man...you sure do take on a project with gusto. Anyhow, the local guys are here to help, if needed. Just ask.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-17-2010, 03:43 PM
"farking Porsche hero"
Rich Lambert's Avatar
Originally Posted by kenikh View Post
...Anyhow, the local guys are here to help, if needed. Just ask.
Hey Brian, I got a new 13 amp angle grinder for my birthday last week. I was going to break it in on the Land Rover frame, but...
Rich
'66 911 #303872
'07 Cayman
'58 Land Rover S2 88"
Old 03-17-2010, 04:33 PM
byfdinky's Avatar
Porsche Crest
I was thinking that your Porsche was either parked next to your Pacific Ocean for awhile, or it's from the Salt Capital, Detroit!
-Bill
1979 911 SC Targa
Old 03-17-2010, 05:45 PM
Hey , Brian
It looks like you've got your work cut out for you for the next year or so !
I've just finished mine , Your Duck Tail turned out great , I'll post some pics this weekend !
Old 03-17-2010, 09:44 PM
Registered?
blee's Avatar
Thanks for the support and kind words gentlemen. I was just about to throw in the towel...just kidding
While we're here, does anyone know what this is:
Is it factory or another patch attempt? I've seen rectangular stampings in this location on other cars but never saw it in "bare metal" form. It's very soft metal, I can move it around - aluminum? What's the purpose? Aren't there issues with dissimilar metals being in contact for long periods? I know it was a definite "no no" with Boeing aircrafts developing corrosion.
Brian
R Gruppe #787
Old 03-18-2010, 07:16 AM
Looks like lead. Probably an unfamiliar sight on a Boeing, but a great factory filler on cars!
'72 911 T/E Silver Targa
Old 03-18-2010, 11:40 AM
(Former 1968Cayman)
It's lead; you'll find it on joints all over the car. I heat it up and coax it into a glass jar. If you have plans on attacking the a pillars at the cowl then you'll really get some experience with it.
1968 911P (Paperweight)
Old 03-18-2010, 03:53 PM
What is a good alternative for its use then? I abhor body filler. Leave the gaps untouched?
'75 911S 3.0L
'75 914 in progress
'67 912R-STi
'99 LR Disco 2
Old 03-18-2010, 03:57 PM
Originally Posted by 84 Carrera View Post
Hey , Brian
Hey Brian, heres the pics of your duck tail that you sold me.
Old 03-22-2010, 04:04 PM
Mich Matt- Replacewith more lead. It's calming to work with and gives great results. Just watch out for signs of mercurial madness. (kidding, do the normal H&S recommendations for lead HAZMAT)
There is a good synthetic lead mimic aroud that is applied the same way- blowtorch etc. Can't remember the name but I've use it with reasonably good results. The real deal is much better though, just be careful. Now, where is my hat? lol.
Old 05-09-2010, 11:27 PM
sc_rufctr's Avatar
I've seen "plumbers solder" used for the same thing.
You know the big thick bars of solder plumbers use for sealing gutters.
If you know someone who works/worked in the telecommunications field they may be able to put you in touch with a linesman.
They make gas tight seals in cable with solder... These guys are good.
Anyway I watched one of these techs re-lead a friends ancient Austin Healy.
Just plumbers solder, a gas torch and a swipe of leather. He made it look easy.
Peter
Old 05-10-2010, 12:42 AM
