Good deal Yea or ney?
Is this a good deal in your prof. opinions for $700.00 us thanks guys. Suspension upgrade for 74-89 911. Complete front struts with spindles with Bilstein HD inserts with camber plates and monoballs. Bilstein HD rear shocks, 22 and 28mm torsion bars, adjustable spring plates with hard bushings. Excellent condition. Used very little. apx 2-3000k miles I have an 86
http://doofdog.homestead.com/files/susp.gif
86Carrera 01 saab Viggen 88 Lebaron(winter Porsche) 41'UTB http://doofdog.homestead.com |
Yes, sounds pretty good, as the tb's and spring plates would be more than that, alone!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Yup!
How will this effect handling? Obviously stiff but will it help eith body roll? what will the hard bushings do for me?
The handling will be affected quite favorably. More positive steering, less leaning, and of course, better traction. Ride quality shouldn't be a problem unless you are running 17s or something. I do believe that set-up will "lighten up" the handling, which would be faster but require more skill through the turns.
