Shaun @ Tru6's Avatar
Availability of RS rear bumper corners?
I've got a set of factory RS quarters that if I stitch them onto my 73T, I'd like to use correct RS steel bumper corners.
are these as rare as hen's teeth? general price? repros available? weld up your own?
what are my options? I'd prefer not to use a one-piece glass bumper. no rush on getting this done, probably a winter 2010 project.
on a separate note, what are your thoughts these days on "permanent" modifications to early cars?
Tru6 Restoration & Design
Old 01-02-2010, 10:52 AM
Bird. It's the word...
Fishcop's Avatar
Shaun, I have a pair of steel corners on my car that have been shaped to match the SC flares grafted to the fender. I'm pretty sure they're not factory - it appears a decent body guy has cut and grafted in metal to flare them out. I suspect this may be a cheaper option to "RS" priced parts...
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-02-2010, 06:26 PM
thanks John, I may go in that direction. I was hoping to have the bumpers on to help line up the RS flares. I've definitely got time to sort it out. I should have a pic or two of that cover tomorrow.
Old 01-02-2010, 06:53 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
I think I have a pair. not sure if they are factory or not. I'll look in the basement for them. what are you looking to spend?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-02-2010, 07:24 PM
Thanks Paul, I found from posting on Early S that you can get these for $565 each new from Porsche. so depending on what you have, we can go from there.
Old 01-02-2010, 07:30 PM
just me
paulgtr's Avatar
565 for one? let me look. I know they are steel and in primer.
I'll snap a pic if I still have them. hold on
Old 01-02-2010, 07:44 PM
just me
paulgtr's Avatar
just went looking and couldn't find them. sorry Shaun. but as I am told, the factory parts are just the narrow fender parts cut and extended to match the flares. so if it is good enough for them, you should not feel bad doing something similar.
Old 01-02-2010, 08:03 PM
Thanks Paul. I have considered that as well. It's a down the road project so I've got time to either find the right pair or imiprove my metal skills to make my own.
Old 01-03-2010, 05:46 AM
MarKoBrow's Avatar
I am actually in the middle of making a set now, the problem I have had is that I really have not been able to model after anything because they all seem different I will post some pictures of my current progress
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 01-03-2010, 07:58 AM
mcfly1013's Avatar
Hey Shaun,
I have a set. One had some work done on it. The other needs alittle work on the bracket. If you are interested I will take some pics and send to you.Let me know
mike
Old 01-07-2010, 04:36 AM
Hi Mike, Happy New Year! How have you been?
Yes, please send me some pics when you have a chance.
Old 01-07-2010, 05:02 AM
