joeybscarface
wheel lock - HELP!!!!!!!!!!!!!!!
went today to purchase two front tires and they have wheel lock on them. where do I obtain the lock????
Old 04-12-2010, 04:17 PM
3/4" hole saw. easy. go slow and it will pop off and not damage the wheel.
206 637 4071
Old 04-12-2010, 04:27 PM
joeybscarface
can I buy the lock??
Old 04-12-2010, 04:54 PM
there are probably several dozen pin arrangements, so i doubt you will have much luck finding a matching removal tool. tapping it off with a punch and hammer rarely works. gotta be pretty loose for that.
206 637 4071
Old 04-12-2010, 05:38 PM
I've used this product to remove a locking wheel nut once. It destroyed the tool but did get it loose enough to remove. Might be worth a try if you don't feel like the hole saw route.
Gator Grip Main Page
Old 04-13-2010, 02:10 PM
MANY times I have used a 1/2 drive impact socket with extension. Find std or metric that almost slides over then carefully hammer it on . Loosen with breaker bar or ratchet with cheater. I also wrap the socket with cloth to limit scratching. Good Luck .
Old 04-13-2010, 02:36 PM
docrodg's Avatar
Try a "stripped bolt socket"... they work well on rounded bolt heads. Hammer it on and give some arm with a breaker bar or impact wrench.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-13-2010, 04:41 PM
80-911SC's Avatar
not to be an ssa but you have the lock you need the key
check sears they have lug removal kit that has removers that will get most off, or resort to a 3/4" galvanized nipple, a hammer and a pipe wrench
Old 04-13-2010, 06:07 PM
guys, there's nothing to grab with those tools. it's flush and flat. hole saw.
206 637 4071
Old 04-13-2010, 07:37 PM
