Wheel spacers
I am looking for information regarding the spacer dimensions for getting stock Fuchs to fill the fender wells of a '78 SC. I'm most interested in the rear but any info about front and rear would be appreciated. I have 16" Fuchs in 6 and 7 inch widths.
Lindy
Old 01-06-2010, 09:25 AM
kodioneill's Avatar
If your asking what size, I would use 1".
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-06-2010, 09:41 AM
nineball's Avatar
i used 23mm on the rear of my 83 with 6/7 and i am happy with the results.
before
after
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-06-2010, 09:42 AM
Nineball,
Your car really looks great with the spacers. Thanks for the info. Did you notice any ill effects or have any problems with this modification? Where did you get yours and what brand are they?
Thanks for your help.
Lindy
Old 01-06-2010, 10:00 AM
abit off center
cgarr's Avatar
Same here, just replaced the stock studs with 66mm studs.
______________________
Craig
G2Performance
Old 01-06-2010, 10:18 AM
nineball's Avatar
Originally Posted by lindy 911 View Post
Nineball,
Lindy
mine are h&r spacers, the kind with the studs already in them. no problems that i have noticed but they have only done about 25 miles since install (right before the snow came). i actually bought 21mm spacers from another pelican who sent me 2.5" spacers instead and then never answered another email or pm from me. i ended up trading them locally with another p-car enthusiast for the 23mm i have now.
Old 01-06-2010, 10:33 AM
Deschodt's Avatar
+1 on 21mm
that should be *enough* to fill the fenders with stock 7s without rubbing, it is on my car (no picture right this second). H&Rs are a good brand, TUV approved, they do come in 21mm which is just under an inch (25mm) with studs, and are easy to find anywhere, even Ebay.
You can either bolt themt on your car and then bolt the wheel on the spacer, or, as I did, install longer studs on the rear of the car: that works for all my wheels (fuchs and superlites), and it's less stuff and unsprung weight to schelp around. In that case you just bang the studs out of the spacers with a hammer, very easily done...
Old 01-06-2010, 10:56 AM
